Transition Help For Click And Lock Wood Flooring. - Flooring - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 01:16 PM   #1
Transition help for click and lock wood flooring.
I am replacing carpet in the loft of my A-frame with click and lock wood flooring. The loft is bordered by oak railing on two sides which then travels down the stairs to the great room. The bottom plate of the railing is what has me baffled right now. If I leave a 3/4" space for expansion I have a visible gap that needs covered somehow. Even if I run the wood right up to the bottom plate, I expect that at some point the flooring will contract and open up a an unsightly gap.
I have attached a pdf of pictures to help visualize my dilemma.
Thank you for taking the time to help.
Logie is offline   Reply With Quote
Old 12-18-2012, 06:57 PM   #2
Rewards Points: 744
undercut the bottom plate or install shoe molding, to cover the expansion gap.
Seattle2k is offline   Reply With Quote
Old 12-18-2012, 07:13 PM   #3
Rewards Points: 13,276
Where are you getting this 3/4" measurement? I've never seen any brand of laminite call for that much of a gap.
Need transition help for click and lock wood flooring. Logie Flooring 0 12-16-2012 01:08 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 11:56 PM
Swift Lock laminate wood flooring on steps? Leche4evr Flooring 1 08-29-2009 01:49 PM
Bruce lock and fold flooring vs pergo 2goresmom Flooring 2 06-15-2009 08:51 PM
had to break down a door, how to repair splintered wood around lock area? mxyplizk Carpentry 17 06-09-2009 09:42 AM
