Transition From Hardwood To Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 12-17-2010, 10:08 AM   #1
Transition from hardwood to tile
I ripped up old damaged hardwood from my dining room that was glued down. The previous hardwood was ran right up to the tile with no transition except for a thin metal strip (actually didn't look bad and had no issues with expansion). ref picture . Question - Should I run my new engineered right up to that metal strip with no transition or should I use a T transition? If I should use a T transition it seems like it would be out in the room too much since they ran the tile to the edge of the door frame. Would I just run a board up to the left and right edge of the T?
BTW, I am gluing down.
Rroberson is offline   Reply With Quote
Old 12-23-2010, 10:16 PM   #2
Update. I am now going to float. No suggestions?
Old 12-23-2010, 10:45 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A "T" molding would sit on top of and lap both the new wood and the tile. It may also be a tripper.
So now you are going to float a floor rather than glue it down?
Now you do need a "T".
You could slightly clip the corners 45 dgrees at the ends on the wood side maybe.
XXX
Laying tile over hardwood stairs steps Flt_Simulation Flooring 12 01-06-2011 08:33 PM
tile to carpet transition qchawkfan Flooring 8 04-25-2010 11:25 AM
installing hardwood against tile doorway tim7488 Flooring 1 03-30-2010 06:13 AM
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 12:55 PM
Hardwood Butting to Tile anthony9887 Flooring 9 03-28-2008 09:30 AM
