Transition From Hardwood To Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 10:42 AM   #1
Transition from hardwood to tile
Hi all:
I recently installed some tile in my bathroom and kitchen and I can't seem to find am adequate transition from the hardwood flooring (oak) to the tile. The top of the tile is almost an inch (thin set, hardibacker and tile) but most of what I have seen available doesn't deal with a transition this large. Any suggestions? I'm open to wood or any other materials. Thanks in advance.
Trustmemalawyer is offline   Reply With Quote
Old 07-27-2011, 11:34 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Not knowing what your skill level is, I'll tell you what I would do as a finished contractor.
Purchase 5/4 x 4 stock to match the wood species.
Bevel the surface on the table saw and power planer to go from flush to the tile to 18" at the wood.
Cut to fit opening.
Sand and stain or poly to match existing wood floor.
3 coats oil poly minimum. This transition piece will get a lot of abuse.
Now let's hear from the others.
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
rusty baker (07-27-2011)
Old 07-27-2011, 01:54 PM   #3
Rewards Points: 5,336
Originally Posted by Trustmemalawyer View Post
Hi all:
For a premade solution. Andersen makes a sloped transition piece used with their patio and french doors.
Ron
B. Franklin 1759
Old 07-27-2011, 08:53 PM   #4
Tcleve: I thought about going that route. I'm not a great woodworker but It sounds pretty straight forward. If I can't find a premade solution, I think I'll go that route.
Old 07-27-2011, 08:54 PM   #5
Ron: any ideas where I can find that piece?
Old 07-27-2011, 11:09 PM   #6
Any window dealer that sells Andersen products. You can go to the Andersen website and put your zipcode in the "Dealer locater" search box. Home Depot sells Andersen.
Ron
B. Franklin 1759
Hardwood 1/8 lower than tile schluter edging Pelican Flooring 4 05-05-2011 06:57 AM
Transition from hardwood to tile 1" higher acerunner Flooring 3 03-01-2011 10:44 PM
Laying tile over hardwood stairs steps Flt_Simulation Flooring 12 01-06-2011 09:33 PM
installing hardwood against tile doorway tim7488 Flooring 1 03-30-2010 07:13 AM
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 01:55 PM
