Transition From Hardwood To Ceramic Tile. - Flooring - DIY Chatroom Home Improvement Forum
Old 03-08-2009, 10:35 PM   #1
Transition from hardwood to ceramic tile.
I need to find a threshold or transition piece to connect a ceramic tile floor with a wood floor. When I planned the tile install, I assumed I would use a 1" by 3" marble sill, and left a 3" gap . I wound up having to put Cementboard down before the tile, and noe the tile floor is appx 11/4 inches higher than the wood floor. Where can I buy a wood threshold to bridge this gap. I thought of using the marble sill, and then a piece of 3/8 or 1/2 " door stop or quarter round to transition up to the tile, but don't like the idea of gluing the wood to the marble. Any ideas would be appreciated.
tmbrink is offline   Reply With Quote
Old 03-09-2009, 12:04 AM   #2
you could make your own out of 5/4 ( 1 1/4" ) oak. Square on the tile side and bevel the other side with a table saw, planer or a belt sander.
Whats wrong with the marble saddle? Add a piece of 1/4 round in front and done. Use sanded grout caulking for the joint between the two. Regular grout will break in time.
II Weeks is offline   Reply With Quote
hardwood to tile transition navychief39 Flooring 8 03-04-2009 06:32 AM
Hardwood to tile transition DIY-Renovator Flooring 3 07-06-2008 01:44 PM
Marble to Ceramic tile transition stormsurfin Flooring 3 06-18-2008 10:46 PM
Transition from Tile to Hardwood anthony9887 Flooring 1 04-18-2008 11:51 PM
Hardwood and Tile Transition Gap mobowhunter Flooring 2 01-19-2008 05:25 PM
