Old 11-28-2009, 11:14 AM   #1
Transition from grouted vinyl tile to carpet
We had the floor coverings for the entire first floor of our home replaced this summer. Grouted vinyl tile in the foyer/kitchen/back hall/bath and new carpet in the LR/DR/FR. I purchased aluminum transition strips and aluminum stair nosings in a satin titanium color to complement the tile color, and these were installed at completion of job. Our home previously used aluminum transitions strips at these same junctions.
My wife hates these strips! Not their color, but the appearance of the strips - coupled with the knowledge of what this job cost.
What can be done to eliminate the strips?
I am thinking of buying aluminum tile edge strips in the same titanium color, pull back the carpet, install the tile edge strip backwards (punched lip under carpet), grout between the tile and strip, then either double over the carpet and staple the edge, or use "Pinless" tack-strips to secure the carpet's edge.
Will this work? Both strips are located in archways, foyer to LR and kitchen to DR.
One stair nosing can be replaced with an oak stair tread nosing carefully cut into the grouted vinyl tile. The other is hidden by the door going into the basement so she really doesn't care (at least I don't care about this hidden one). Obviously it would have been best to have this tread nosing installed prior to the floor, but when the floor covering store says "use Aluminum" and my wife says "OK", I had o reason to do otherwise - at the time.
What do you guys think?
Thanks,
MI-Roger is offline   Reply With Quote
Old 11-28-2009, 01:19 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Many people consider it a no-no, but I put tack strip 3/8 from the tile like I would a wall and trim and tuck. It makes a nice clean transtion. Some say the carpet will wear out on the strip, but I could show you some I did 10 years ago that still look nice. You also could use z-bar.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 11-29-2009, 01:55 PM   #3
Similar to the above post... Put a double row of tack strips 1/2" inch away from the tile. Cut the carpet 1" from the tack strip and fold the carpet under so the nap is in contact with the tile as you push it back onto the tack strips. This gives you a nice finished edge and compensates for slight irregularities in the edge of the tile.
Rege
RegeSullivan is offline   Reply With Quote
Curved tile to carpet transition toocheaptohire Flooring 5 04-16-2009 03:37 PM
Redo transition from carpet to tile bkeech Flooring 1 11-08-2008 08:02 PM
Good equipment to use for carpet cleaning? Beth777 General Discussion 5 08-29-2008 09:16 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
carpet to tile transition jeeper36 Flooring 1 10-26-2007 11:16 PM
