Transition From Brick Floor To Brazilian Cherry Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 12-08-2008, 11:18 AM   #1
Rewards Points: 22
transition from brick floor to brazilian cherry floor
I need some help here, i've installed brazilian cherry engineered wood(5/16") and have my 2 thresholds from the cherry floors to my 2 bedrooms with carpet but have a question before i finish this job completely, i've got brick floors in all my bathrooms and the height difference from my wood floor to the brick floor is about 1/2" to 9/16", my question is do i use a reducer or a transition piece? If i use a reduce, which butts up to my brick floor, i'll have to use a grinder to grind back the bricks as they were not finished evely going across but that shouldnt be a problem. If anyone can shed a light on what is the correct way of finishing this please let me know.
Rockey
rockey is offline   Reply With Quote
Old 12-08-2008, 11:29 AM   #2
Floorwizard's Avatar
a reducer will work fine.
the lip of the reducer goes over the brick, and it slopes down to the wood.
Just like a wood reducer to vinyl, but reverse.
Floorwizard is offline   Reply With Quote
Old 12-08-2008, 11:35 AM   #3
Rewards Points: 22
Thanks for the reply but i have another question and please excuse my ignorance. From what i've seen on the web the Reducer, from what i've seen, butts up to the brick/wood and slopes down toward the wooden floor but from what i've seen the transition actually laps over the brick and then slopes down toward the wooden floor?
Isnt this correct?
just trying to make sure which moulding i need to order.
Old 12-08-2008, 11:39 AM   #4
an overlap reducer is what you need. A flush reducer would be more difficult to deal with as you need to gring down the brick and the overlap will help cover some up.
Old 12-08-2008, 12:55 PM   #5
Rewards Points: 22
Thanks for the reply, i will go with the overlap reducer and go from there.
Rockey
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Installing 3/8" solid Brazilian Cherry silverbullet Flooring 6 01-02-2009 05:58 AM
possibly pulling up recently laid Brazilian Cherry wood floor rockey Flooring 6 11-05-2008 01:03 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Tub to floor transition Richo Plumbing 17 01-18-2008 06:16 AM
