Transition Between Wood And Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 11:20 PM   #1
Rewards Points: 51
Transition between wood and carpet
Another transition question. So, I've left the carpeting in the bedrooms, and now I need to know how to transition the new hardwood floor in the hall to the carpet in the bedrooms. The pile of the carpet is at about the same height as the wood. I know I shouldn't use T-molding, I assume I should use Threshold molding. But, how do I do it? Do I put the threshold over the carpet or over the wood? And if I put it over the wood, how do I secure the carpet? But if I put it over the carpet, how do I ensure the expansion gap for the wood? Please advise
preciouschristy is offline   Reply With Quote
Old 08-20-2009, 02:21 PM   #2
Wood Floor Guy
Threshold for sure! Butt it to the carpet tackless strip, and run the wood just a little bit under the lip to allow for the wood to expand!
Over pltwood, predrill and nail through the "meat" of the threshhold into the subfloor. Putty the holes. If you're over concrete, use construction adhesive to adhere the threshold to the slab.
Good luck!
Wood Floor Guy
Last edited by AtlanticWBConst.; 08-20-2009 at 03:50 PM. Reason: RULES VIOLATION: Advertising Link Removed From Signature
Wood Floor Guy is offline   Reply With Quote
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 08:16 PM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 01:42 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 09:35 AM
Wood floor or carpet? darsunt Flooring 9 08-04-2007 12:12 AM
