Transition Between Hardwood And Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 11:29 PM   #1
transition between hardwood and laminate
Hello,
I replaced some damaged hardwood planks at the threshold between kitchen and dining room and I'm having a little difficulty with the transition. The dining room is oak hardwood, 0.75" thick. The kitchen is vinyl with wood subfloor and the total height is 1 inch.
I bought T-molding with a reducer but the U-channel is only 3/8" high, so it sits too deep in the groove between the 2 floors. In other words, the T-molding does reach far enough to click into place in the u-channel.
I've considered:
1. putting shims in the gap to bring the U-channel up so that the T-molding will click into place.
2. ripping another plank and bringing the hardwood right up to the vinyl (leaving an expansion gap) and using reducer (not a T-molding)
What are the pros and cons of each?
Thanks.
bernie1971 is offline   Reply With Quote
Old 08-26-2012, 05:24 AM   #2
woodman58's Avatar
Go purchase a real wood T-mold that matches the wood laminate and nail it in place. I laminate t-mold will end up breaking on uneven surfaces.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
bernie1971 (08-26-2012)
Hardwood vs Laminate Yuri23 Flooring 15 10-30-2011 02:55 PM
Laminate & hardwood in the same room, good or bad idea?? phatjoe Flooring 10 05-14-2011 09:57 PM
Basic questions for hardwood or laminate install Demus Flooring 3 01-17-2010 06:38 PM
Hardwood and Laminate Transition seanf12 Flooring 2 01-14-2010 01:34 PM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 08:43 PM
