Transition Bar - Flooring - DIY Chatroom Home Improvement Forum
Old 08-05-2013, 09:40 AM   #1
Rewards Points: 1,050
Transition bar
Hello
I have installed a transition bar (oak from Home depot) - 44 mm wide
I hade to trim it to make it 36mm wide - no problem with my table saw
But my wife finds it too thick....
How could I make it a little bit thinner: Using the table saw seems not safe at all.....Is it feasible with a router table?
french_guy is offline   Reply With Quote
Old 08-05-2013, 12:28 PM   #2
Rewards Points: 13,450
No one here can see what it looks like now.
There's dozens of different strips it could be.
Would be best to post a picture.
Also need to know what type floorings involved.
Old 08-05-2013, 03:29 PM   #3
Floor is 12mm laminate
1 room is the hallway, and the other room is the master bedroom Ė planks are perpendicular, so I need a transition bar to hide the expansion gap in between
I bought a transition bar at Home Depot (natural oak) and stained it - Width is 44 mm, and I think thickness is ~9 or 10mm
http://www.homedepot.com/p/Traffic-Master-Oak-Seam-Binder-18576/100354277#specifications
I was able to trim it to make it 36mm wideÖ..This is what I needed, and Itís fine
But once installed, I have to admit itís a little too thick..So what would be the best solution to make it a little bit thinner? Let say make it 5mm thick?
Old 08-07-2013, 07:03 PM   #4
Rewards Points: 81
The more knowledgeable are free to correct me, but, I think you used the wrong trim style. I think you should have used a T-mold strip. Those edges would have been thinner.
MaineLL is offline   Reply With Quote
Old 08-07-2013, 08:45 PM   #5
I install for a living and yes tmold. Little pricier but more professional look
Depotfloors is offline   Reply With Quote
Old 08-08-2013, 06:15 PM   #6
Rewards Points: 3,520
[QUOTE=french_guy;1225266]Hello
Why buy it from Home Depot if you have a router,make your own that's what i do,and yes on the t-mold.
Canarywood1 is offline   Reply With Quote
Transition from Vinyl to Wood Question petros151 Flooring 3 02-16-2012 11:42 AM
door jamb cut over transition rtoni Building & Construction 4 10-28-2011 03:50 PM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 12:12 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
1.75" room / floor transition MrLinux Flooring 1 03-11-2008 02:19 PM
