Transistion From Hardwood To Ceramic Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 10:51 AM   #1
transistion from hardwood to ceramic tile
I am a novice and I need your expert advise. I am installing hardwood in the family room which opens one side to the foyer entrance hallway and the other side to the kitchen. The entrance from the foyer to the family room entrance already has a 3" marble slab(transition) horizontally laid. My question is do I need a transition of 3" hardwood which needs to be vertically laid or I don't need a transition to the ceramic tiles at all into the kitchen. Just have the hardwood and tiles meet without any transition.
I am confused and need yr suggestion. thanks
gully is offline   Reply With Quote
Old 10-14-2011, 09:39 PM   #2
DIY staff
Rewards Points: 7,174
If the hardwood is the same height as the tile --simply butt a strip of hardwood along the tile and work the wood from there.
Let us know if the floor height are different---Mike---
Old 10-15-2011, 01:21 AM   #3
Need more info
Do your boards run with or at an angle to the tile border? If they but up to the border then I would just add a wood transition strip. Mostly because it's easy to run your saw through all the end pieces at the end of the job to slip the wood border in and you can also mill your strip down on one side if it's higher than the tile. Don't forget to keep a 3/8 expansion space between the wood and tile. You can fill it with a caulk to match your grout
Orville is offline   Reply With Quote
Ceramic tile over subfloor in Kitchen pinkertonpv Flooring 11 01-12-2013 12:40 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
tile over hardwood floors MnMan Flooring 1 07-30-2008 05:39 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 12:08 PM
