Old 10-27-2009, 09:13 AM   #1
Default Trafficmaster groutable vinyl
Hey folks first post.
I'm installing(preparing to) groutable vinyl(sticky backs)..my kitchen floor has sheet vinyl on it now, house is 6 years old. Have tested subfloor by pulling up old floor,looks good,just white glue residue(still slightly sticky). Old floor seems to come off without leaving anything behind.
Should I lay new tiles down directly on the subfloor or take off old glue? This would be near impossible by the looks of it?
Any help/suggestions would be appreciated
Spunner is offline   Reply With Quote
Old 10-29-2009, 09:16 PM   #2
Default Suggestions
  1. Remove the old underlayment too, this is the luan or thin plywood under your existing vinyl. Then install new underlayment with staples on 3 to 4 inch centers throughout. Some underlayment comes printed with grid for stapling pattern.
  2. Do not use sticky back tiles.
  3. Buy groutable vinyl tiles which are set onto a trowel applied mastic layer. Mannington and Stainmaster are two such brands. Konecto is another brand that I am fairly certain makes groutable vinyl tiles.
  4. Congoleum also makes this product but has had many problems with their groutable tile. An experienced installer told me he has seen numerous Congoleum floors where the entire wear layer separates from the tile within a few months. He said he has never had a "call back" with the Stainmaster or Mannington products in the three years he has been installing them
  5. Buy from a reputable floor covering store and not one of the big box stores. The big box places often sell identical appearing brand name products that are thinner and less durable than those sold by the specialty stores.
We had 30 sq yards of groutable vinyl installed this summer and we love it! Everyone who sees it immediately thinks it is ceramic or porcelain tiles, until they realize is is warmer and softer underfoot than ceramic tile floors.
MI-Roger is offline   Reply With Quote
More On This Topic
If you're looking for carpeting you can install yourself consider carpet made in tiles of varying sizes. The major benefit of carpet tiles is the ability to replace only 1 or 2 tiles if staining occurs, while leaving the rest of the carpet intact. Follow... Read More »
Now we’re going to talk a little bit about the recycled products. The terrazzo type countertop material is usually a ¼ inch, you can even order it thicker than the ¼ inch, ½ inch, and it does have to have underlayment so it doesn... Read More »
Hi, this is Brian Carter on behalf of Expertvillage.com. I have 10 years of ceramic tile installation experience. Today I am going to show you how to make the three-sided cut using the ceramic tile wet saw. We need to make sure that we know where we are... Read More »
Hi, this is Brian Carter on behalf of Expertvillage.com. I have 10 years of ceramic tile installation experience. Today I am going to show you how to make straight cuts. When you are cutting a tile you need to make sure you have a mark, you should always... Read More »
Roofing Safety Tips
Roofing Safety Tips by Expert Village
Hi, I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The product must be kept covered and dry until completely installed. If staked tiles become wet they should be immediately separated and dried... Read More »
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-10-2009 12:50 AM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 07:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 02:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 05:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
