Old 03-23-2009, 02:19 PM   #1
Unhappy
Trafficmaster Allure and Concete Sealer
No, this is NOT a is Allure good or not post. I'm just moving forward.
Before I began installation, I did a moisture test on the slab. Bone dry as I expected. I had a gallon of leftover ProShield HPG (rubbery membrane) sealer so I decided to roll it on for an extra layer of protection.
As I've started to get a walkable area of Allure down (about 40%), I'm noticing a slight "sticky" sound from the floor. Seems like in areas where the slab isn't perfectly flat, and they're many, there's a slight give in the floor that makes the sound. The questions are:
1. As the ProShield cures, will it's tacky feel of it lessen?
2. Is this a permanent deal between the membrane and the slick underside of the Allure?
3. If I'm stuck with the with question 2, can I paint some primer of the sealer and fix it that way?
The company that makes the stuff doesn't have a web site or phone number on the bucket. Can't find them on the web via Google either.
Any insight would be much appreciated.
Alex3D is offline   Reply With Quote
Old 03-24-2009, 07:26 AM   #2
never heard of any of the products or names you mention,,, however, as long's there's a epa, there'll be a material safety data sheet AND product sheet somewhere.
Manufactured by Superior Adhesives and Chemicals. All that I was able to find was a P.O. Box 78/8515, Ottawa Lake, MI 49267. The Tile Shop is the distributor.
ProShield HPG - Allure - ProShield - TrafficMaster - they can't hide ! reboot your googler
yesitsconcrete is offline   Reply With Quote
Tags
allure, concrete, sealer, trafficmaster
More On This Topic
If you are planning a concrete project, you will be dedicating your time and money to making it perfect. Whether you will be doing the job on you own or hiring a contractor, there are a few things you should think about before getting started. While it... Read More »
Not everyone can get the hang of the pottery wheel right away. Luckily, beautiful and unique pottery can be crafted with little more than a pair of hands. There are several techniques for hand building, one of the most common being the use of clay slabs... Read More »
Hi I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods, and we're going to do some work for you today on Expert Village. God, this is so cool. Now Tony is going to shoot the sealer. We've got our very nice paint booth... Read More »
Changing the Air Source Adapter or ASA on your paintball gun is an easy way to add increased functionality. An on/off ASA allows you to turn off your air supply without removing it from the gun which also makes removing the tank easier. Read More »
Hand Making a Clay Slab
Hand Making a Clay Slab by Expert Village
There are two ways to create a clay slab and by hand is the old fashioned way. Learn some tips on how this is done from a clay expert in this free video clip. Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
