Old 11-16-2008, 11:42 AM   #1
Question Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas
I think I have read all the postings about Allure flooring. Most were involving installation indoors, all wll be them in bathrooms, basements etc. I would like to install it in my 21' x 32' garage that currently has an epoxy coatng which over the years has yellowed and worn in places. We use the garage for parties and large gatherings (I'm Italian=large family)
When I search the Home Depot website for garage flooring it comes up with a jigsaw puzzle type of flooring I am not interested in. The Trafficmaster product shows up in Commercial grade flooring. The description for the product is this:
Durable, waterproof, ice, heat, and road salt resistant allure Commercial can be used in most rooms, including garages,...
I'm in NE Ohio, and when not using the garage for parties we use it for, you guessed it, cars. Cars that are covered with snow and road salt, and swings in temperature from 90 degrees to minus 20. The garage is insulated and never gets below 40 degrees. (What temp do I acclimate the product to? Current conditions?)
I am also concerned about mold as I read early on one writer had a problem. There is no drain in the garage. I thought about caulking the perimeter.
So I need some direction here. Pricing will be about $2,100 and I will be doing it myself. and at $2,100, if it looks crappy my loving wife of 25 years will... no need to say any more.
To the experienced professionals: Would you do it?
To my other new DIY friends who have installed, do you think it will hold up?
Thanks for your time
bennyjets is offline   Reply With Quote
Old 07-02-2009, 12:42 PM   #2
Default how did your installation go?
I am considering the product myself and am curious to see if you went ahead with the project and can comment?
rrl_36 is offline   Reply With Quote
Old 07-31-2009, 12:01 AM   #3
Default How did it work?
I am considering this option and live in Missouri with weather like yours. Did you proceed and what are your thoughts? Thank you.
ReneeB is offline   Reply With Quote
Old 08-10-2009, 12:50 AM   #4
I am considering the Trafficmaster Garage Allure Flooring ($1.99/sqft) for my unheated garage.
They are waterproof, do not need to glue them down and easy to install.
I live in Ottawa, On. where it snows several months of the year, so I get a lot of snow and salt in the garage.
However, I wonder whether they trap moisture between the concrete and the bottom of the product, and the likelyhood of mold developing under the floor.
Any idea or other concerns I should be aware of?
xinai is offline   Reply With Quote
More On This Topic
The garage is one of the largest spaces in the home and it is usually the most congested and cluttered. A simple solution for garage clutter is to use well designed storage systems. Here is how to design a garage for maximum usability and storage. Read More »
Wakeboard towers add value and style to your boat. Not only are they practical for holding wakeboards, but they are also great for mounting speakers and other accessories. Besides figuring out how to build it yourself, there are several options available... Read More »
On behalf of Expert Village, my name is George Engle with Mr. Fix-It Handyman here in Miami, Florida and today I am going to showing you how to install weather stripping on the exterior of your garage door. All right we are going to go into the removal... Read More »
On behalf of Expert Village, my name is George Engle with Mr. Fix-It Handyman here in Miami, Florida and today I am going to be showing you how to install weather stripping on the exterior of your garage door. Okay in this clip, I am going to show you... Read More »
Allure Vinyl Flooring Ash74 Flooring 18 08-17-2009 11:03 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 07:15 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 02:04 PM
hardwood flooring over sheet vinyl floor chrish Flooring 0 09-10-2007 09:13 PM
mold under vinyl flooring sum07 Flooring 0 08-27-2007 01:31 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
