Traffic Master Peel Off Vinyl Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 11-02-2007, 01:42 PM   #1
fishtayl
Traffic Master Peel off Vinyl Tiles
I am installing the Traffic Master peel off vinyl tiles over a product called Subflor (http://www.subflor.com/ADVANCE/home.asp) in my basement.
Some of the tiles are sticking really well, others are peeling a bit and yet others make a sound when stepped on (probably a sign of the middle not sticking).
I called traffic master and they think it shouldn't be installed on top of Subflor, however, the guys at Home Depot say it is fine.
Conflicting views...very frustrating. Since I have the space half done already, I would like to know before wasting any more $$$.
Anyone?
fishtayl is offline   Reply With Quote
Old 11-02-2007, 02:22 PM   #2
jproffer's Avatar
Rewards Points: 706
There's your answer right there. It sux that you already bought the Subflor product, but none-the-less, if they say not to use it, I wouldn't use it.
Rule #1 of any DIY job: Don't believe everything you hear at HD or Lowes or Menards, or any other big box store. If the people there knew what they were talking about, they wouldn't be working there (most of them). Always believe the people that make the product over the people that sell it.
jproffer is offline   Reply With Quote
Old 11-02-2007, 02:33 PM   #3
Been here before!!!
I have a simple solution for you. You can simply pick up some mastic and trowel it on. Let the glue set until it is tacky (Very Important if you intend to not have glue coming back through the cracks of the tile your installing} Don't be aftaid to let it set until it is almost dry before installing the tile. Or you could butter the back of each tile slightly keeping it from the edges so it won't seep through the cracks. Personally, I would glue it......let it dry a bit... then install the tile. I have done this many times before. Its fine!!!
localtradesman is offline   Reply With Quote
Old 11-02-2007, 03:24 PM   #4
HJ1
tile man
Read the instructions for Subflor on their website. It says "Installation of vinyl tile requires a 1/4" underlayment such as plywood to first be fastened to the Subflor panels."
Did you install an underlayment over the Subflor?
Nobody at home depot is gonna warranty your install so dont waste your time asking them anything. They dont know the right answers anyway. Always contact the manufacturer if you are not sure.
HJ1 is offline   Reply With Quote
Old 11-03-2007, 12:56 AM   #5
fishtayl
Lot's of ideas here...thanks! I'm learning pretty quickly that HD is not the be all and end all of knowledge. Getting that info from the manufacturer was annoying since I already layed 40+ tile and bought 100. But better know now than later.
How long until tiles can have heavy traffic? leted_82 Flooring 2 07-31-2007 07:10 PM
Tiles over existing vinyl Work is good Flooring 3 07-11-2007 11:10 PM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 02:10 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
