Tongue & Groove Router Bits - Flooring - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 10:58 AM   #1
Just call me Andrew
Rewards Points: 1,020
I want to buy router bits to make my own tongue & groove joints in wood flooring.
In doing a google search, I see lots of different sets, varying in price:
http://www.google.com/search?q=tongu...w=1251&bih=486
Is any one much better than the other?
I am hoping to find one that would be compatible with existing flooring to use when cutting out & replacing existing boards...is the size of the tongue and groove pretty standard?
Andrew
secutanudu is offline   Reply With Quote
Old 09-29-2011, 11:41 AM   #2
DIY staff
Rewards Points: 7,174
Here this should help---Cutter Profiles for Tongue-and-Groove Flooring
Regular T&G bits won't work well for flooring--there is a slight setback on the bottom cutter to allow a tight joint at the top edge even if the floor is not perfectly flat-
Also the tongue is shallower than the groove to allow for a bulged tongue from having a nail driven into it---
You will benefit fro having two router tables set up for the flooring operation so you don't have to waste time on set ups or the risk of goofing up a set up---
DangerMouse (09-29-2011)
Old 09-29-2011, 12:14 PM   #3
Just call me Andrew
This bit is actually for a friend who installs flooring.,..he wouldn't use this too much, really just on repair jobs (he would never on a whole floor). So time wasted isn't really a concern.
Do they make T&G router bits that are made for flooring?
Andrew
Old 09-29-2011, 12:24 PM   #4
DIY staff
Yes--did you look at the article on routing the tongue and groove? That's the kind is set needed---
I don't know who stocks them---I've never made flooring---some one here will know----Mike---
How to repair tongue and groove that is subfloor cosmicblu Flooring 1 08-19-2011 05:12 PM
siding nail gun or 15 ga. finish nailer for tongue and groove siding Lbert Tools 4 11-03-2010 07:58 AM
Replacing tongue in groove with support below odonata3 Flooring 0 10-20-2010 10:40 AM
Install Cabinets directly above Tongue & Groove? caezaar Building & Construction 13 07-06-2010 09:50 PM
tongue and groove fence pickets - bad idea ? JoeT Carpentry 6 05-23-2008 11:00 AM
