Tongue And Groove Porch Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 08:42 AM   #1
Tongue and groove porch flooring
I am going to be laying down new tongue and groove flooring on my porch, ya know the kind with the littel bead in the middle that you find on old houses. I was wondering what size nails to put in my nail gun to nail through the tongue?
Thanks guys!
cambishop is offline   Reply With Quote
Old 08-08-2011, 10:00 AM   #2
Rewards Points: 150
If you were blind nailing down by hand the nail size would be a 6 casing galvanized nail. That nail is 2" long.
TrapperL is offline   Reply With Quote
Old 08-08-2011, 12:49 PM   #3
Rewards Points: 5,336
Thanks guys!
Prime all the sides of the flooring, before you install it.
Are you sure this beaded wood is flooring? Beaded wood is usually used on walls and ceilings and is too soft for flooring.
Ron
B. Franklin 1759
Old 08-08-2011, 02:15 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Tongue and groove porch flooring is often straight grained red fir (if you can even find it anymore). Beaded boards are normally some kind of pine. Wouldn't work very well for a floor. Exposed to the weather it will rot away in no time.
Old 08-14-2011, 11:06 PM   #5
remodeling pro
Thanks guys!
Beaded t&g is not used for flooring, it is used for ceiling or walls.
I only use 15ga stainless nails for porch decking. 16ga don't have enough holding power, and "galvinized" gun nails will be corroded away in less than 2 years.
The best is still genuine hot dipped 6d hand nails IMO, but extremely labor intensive.
troubleseeker is offline   Reply With Quote
Old 08-22-2012, 05:57 PM   #6
Prime it how?
What would I use to prime it?
thanks
hcraig50 is offline   Reply With Quote
Old 08-22-2012, 08:14 PM   #7
Rewards Points: 13,450
Also how thick is it, real flooring will be at least 3/4, the better stuff is 5/4 (1")
Beaded used on walls and ceilings will most often be only 1/2".
Main reasons bead is not used for flooring is it would be a real pain to sweep off and when it rains the water can lay in the beads, which expose the grain leading to rot.
Old 08-24-2012, 09:56 PM   #8
Haverhill Trade 1965
thanks
Primer of course. Best I have used is PrimeZ or Gripper.
Duckweather is offline   Reply With Quote
tongue and groove porch R&R rojk68 Carpentry 7 12-19-2012 09:36 AM
Adhesive tongue and groove flooring dougf Flooring 1 01-31-2011 08:20 PM
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 12:21 PM
Replacing tongue in groove with support below odonata3 Flooring 0 10-20-2010 10:40 AM
1x4 or 1x6 flooring NON tongue and groove easy? c0bra969 Flooring 2 11-16-2009 11:03 PM
