Tongue And Groove - Flooring - DIY Chatroom Home Improvement Forum
Old 05-18-2007, 03:25 PM   #1
Tongue and groove
I am installing tongue and groove flooring on my floor. I have installed two full sheets on the floor and there is a 6 inch gap left to fill. I know the answer to this but do I have to sacrifice the end of a new full sheet of tongue and groove to complete the floor or is there another solution. I know I will have to but I thought it was worth asking about.
miami vice 25 is offline   Reply With Quote
Old 05-18-2007, 03:36 PM   #2
Home Improvement Guy
ron schenker's Avatar
You answered your own question. Cut it. Or find a 6" thick baseboard
BTW what kind of flooring is it and how come you only needed 2 sheets. I'm picturing either 3 1/4" wide hardwood, or clik and lock laminate.
ron schenker is offline   Reply With Quote
Old 05-18-2007, 03:44 PM   #3
I have installed two full sheet and two 31 inch sections. One full sheet and and 31 inch section side by side. Yeah I knew I had to cut it I just thought there was another way. I was simply thinking about the cost of the whole sheet in the area of $11.00 but it has to be done.
Old 05-18-2007, 03:59 PM   #4
Oh, are you talking about 4x8 sheets of T&G plywood?
Old 05-18-2007, 04:11 PM   #5
Yes sir.....
Old 05-18-2007, 09:48 PM   #6
remodeling pro
What kind of flooring comes in sheets?
troubleseeker is offline   Reply With Quote
Old 05-19-2007, 06:33 PM   #7
See post #4
Old 05-20-2007, 10:10 AM   #8
When I refer to sheets I mean 4 X 8 boards of plywood.
Old 04-04-2012, 06:35 PM   #9
Yes cut the 6" if not the flooring, if stepped on could give away and cause the
flooring to break.
lynn Corum is offline   Reply With Quote
Tongue and Groove Ceiling install....questions... Dr. Jim Remodeling 9 04-08-2012 12:14 PM
