Old 03-11-2009, 05:49 PM   #1
Toilet or Tile First?
I'm remodeling two bathrooms. Both had vinyl floors, which have been removed down to the concrete. I plan to replace both toilets, as well.
Should I remove the toilets, tile and then replace the toilets? or
Replace the toilets and then lay the new tile? In other words, should toilets be installed ON TOP OF the new tile???
Help, please!!
Roxanne Akimbo is offline   Reply With Quote
Old 03-11-2009, 06:00 PM   #2
Tile first. Toilet on top of tile. That way if the footprint of a later replacement toilet is different you won't have to replace the tile.
Old 03-11-2009, 06:19 PM   #3
the Musigician
DangerMouse's Avatar
what he said....
DM
RU Crafty? Come join us at www.CraftForum.com !!!
For some Magical Fun, go to:
http://www.youtube.com/user/MickeySoume
Now Featuring: My Canine Assistant Picks the Magic Rising Card!
Old 03-11-2009, 07:24 PM   #4
Would the plumber who's going to install the new toilet agree with you?? Or will he say the wax seal may be compromised by laying the toilet on tile instead of concrete?
Old 03-11-2009, 07:37 PM   #5
37 year installer
rusty baker's Avatar
The tile must be installed first.
Old 03-11-2009, 07:51 PM   #6
the Musigician
he'd likely say nothing and just use a ring with plastic flange.
DM
Old 03-12-2009, 07:32 AM   #7
ccarlisle's Avatar
The plumber should be able to deal with either situation.
ccarlisle is offline   Reply With Quote
Old 03-12-2009, 08:44 AM   #8
DIYer
jpsmith's Avatar
This is a DIY forum, so someone has to say it... replacing a toilet is very much so a DIY job! Sure, scraping the old wax ring is kind of gross, but it's not rocket surgery. Just be sure to buy a couple of wax rings because you're going to mess up the first time setting the bowl down. If you don't, return the extra one. They're only like $3.
If your closet flange is slightly below the tile, buy a reinforced wax ring, as was mentioned. Even go with an extension ring - the plastic sticks down a little farther.
-Jack
jpsmith is offline   Reply With Quote
Old 03-12-2009, 08:54 AM   #9
the Musigician
i totally concur.....yeah, it's gross and yucky, but a ten year old could do it.....
DM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Re-tiling a bathtub surround BillyB44 Remodeling 37 05-13-2009 08:05 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
tile and toilet flange question rbaggett Plumbing 2 11-13-2008 05:43 PM
Toilet rocks on tile floor Richo Plumbing 9 05-03-2008 07:44 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
