Old 03-18-2011, 11:29 PM   #1
Toe Board on stair landing
Our carpenters glued down the toeboard on my upstairs landing and then nailed in several spots.
I had stained the wood and had to fill the nail holes. Never could find an exact match, so I applied stain over the filler and tried to blend it in.
Didn't work. Can tell where it was applied. I need help since I can't take the toeboard up and must repair it in place.
lizdick is offline   Reply With Quote
Old 03-19-2011, 06:49 AM   #2
woodman58's Avatar
What kind of wood is it? A picture would help explain what it looks like. You can find filler to match most an wood color. Try Woodcraft on line. They have filler kits.
woodman58 is online now   Reply With Quote
Old 03-19-2011, 11:44 AM   #3
It is hickory. The problem I am having is do I make the situation worse by removing the already filled holes and start over or try to somehow make what I have already filled in blend in and create a smooth color on the toeboard.
Would applying clear wax and buffing smooth it out?
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 10:13 PM
Tile landing Carpet stair Transition Tmint Flooring 1 02-04-2011 05:35 AM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 08:48 PM
Stairway landing code question. Bcoleman6 Building & Construction 4 06-26-2008 10:43 AM
4'x7' Landing in the middle of stair, glue or floating? liguowei70 Flooring 1 09-06-2007 06:03 PM
