Tips For Using Concrete Slab As Finish Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 08:52 PM   #1
DIYer
Rewards Points: 93
Tips for using concrete slab as finish floor?
Ill be building a 10x12' slab on grade (insulated) 1 story cabin in the coming months and am planning to keep the concrete as the finish floor.
Would it be practical to apply a self leveling compound to the entire floor surface and treat that as the finish floor? If so, can this be tinted with color?
dwoloz is offline   Reply With Quote
Old 12-07-2010, 10:39 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why would you want to do that?
What would be wrong with just using the original slab?
I must be missing something.
XXX
Old 12-07-2010, 11:06 PM   #3
DIYer
Rewards Points: 93
My reasoning is to reduce the number of materials used. I figured "Why buy flooring when I already have a perfectly good slab"
I could just float the slab nice and even and use that, yes, but I thought maybe a self leveler could give it a more refined smooth finish
Edit: Also forgot to mention, the floor would be thermal mass to collect heat in the winter
Old 12-07-2010, 11:12 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well maybe...
There are self levellers made for that specific reason.
If you are building a new slab why would you need a self leveller over the top of it?
XXX
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
How to cover a hole in a floor slab tomseeley Flooring 2 11-16-2009 12:14 PM
cold concrete floor RuthP Flooring 4 02-03-2008 10:13 PM
Join Wood Cyc Ramp to Concrete Floor Bigboots Building & Construction 3 11-27-2007 09:52 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
