Old 12-06-2011, 11:04 AM   #1
Tips on tiling in a house on blocks
I purchased a fixer upper that is on blocks. Other than using Ditra is there any tip on laying tile and preventing cracking?
puppsmummy is offline   Reply With Quote
Old 12-06-2011, 11:31 AM   #2
Tileguy
Bud Cline's Avatar
What makes you think DITRA is the answer?
What's the floor made of now?
What size are the floor joists?
What is the species of the floor joists?
What is the spacing of the floor joists?
What is the unsupported span of the floor joists?
What material is on top of the floor joists and how thick is it?
What do mean it is on blocks?
Old 12-07-2011, 03:53 PM   #3
I am guessing it is on a cinder block foundation......but just guessing..
fixrite is offline   Reply With Quote
Old 12-13-2011, 11:23 PM   #4
The house is on cinder blocks. We hope to change that with piers eventually. The joists are 24 inches apart and i beleive 2x12. We are not excited about the sub floor. Have not interigated but seems to be 1x6 with a half inch sub floor and old hard wood on top. House built is 1960. Dont know type of wood but joists are SOLID.
Old 12-13-2011, 11:34 PM   #5
Tileguy
Bud Cline's Avatar
Floor joists twenty-four inches on center are problematic at best and will require a second layer of plywood to counteract deflection between the joists. The thicker the better. Ceramic tile is sometimes discouraged with such a structural arrangement but not impossible.
DITRA wouldn't be the answer unless the subfloor is beefed up a little.
basement house inspections/ problems base_build_01 Building & Construction 1 08-01-2011 09:38 AM
Considering buying a house that needs regrading HELP Dr.JUSC Landscaping & Lawn Care 9 06-16-2011 11:58 AM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 12:43 PM
Weird wiring in house fdmillion Electrical 7 02-26-2010 01:57 AM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 06:58 PM
