Old 09-21-2009, 04:30 PM   #1
Default Tips for Leveling Fridge
We bought a new fridge.
The floor slopes 1/2" on the 30" fridge width. The old fridge was shorter so the 1/2" slope was not very apparent against the upper cabinet.
The new fridge should come about 2" under the upper cabinet. I think to 1/2" slope will be very apparent.
It seems that the new fridge is not able to be adjusted side to side. Only front to back.
I'm not ready to take the floor up or install teleposts in the basement yet.
I was thinking of ripping a 1/2" plywood to stick under one side.
Is there something else I can do?
Karl
unixb0y is offline   Reply With Quote
Old 09-21-2009, 05:13 PM   #2
I'd shim it.
47_47 is offline   Reply With Quote
Old 09-21-2009, 07:05 PM   #3
WaldenL's Avatar
It's likely that the weight is on just 4 wheels on the bottom, so you'd only have to shim the low two wheels. It would likely also do the refrigerator doors good to be level. Shouldn't be too hard, just some trial and error. If it's really 1/2" just throw a piece of 1/2" ply under the low side like you said.
WaldenL is offline   Reply With Quote
Old 09-22-2009, 04:44 PM   #4
Most new fridges have adjustable wheels or legs for leveling. If not all four corners at least the front will be adjustable even on less expensive models.
Rege
RegeSullivan is offline   Reply With Quote
More On This Topic
A dry bar adds value and function to any master suite, media room, dining or living room. Here you’ll be able to create a basic dry bar using CAD and then add your own creative touch. You can always add a wine glass holder, under-counter... Read More »
All beautifully crafted TV cabinets start with a basic TV cabinet design. Then the carefully selected applied moldings and hardware are added. Once you have created either your basic or customized TV cabinet it can then be added to any wall, niche or... Read More »
With the push to go "green," many companies are answering the call. Contractors are among the companies as well as people using eco-friendly products in building and remodeling. Kitchen cabinets are among those items available in eco-friendly terms. Use... Read More »
Hi! I'm Betty Ingham speaking on behalf of Expert Village. Even though we did most of the work on this house ourselves, we were on a limited budget because of what we had to do was just so massive because we had to replace floors and walls and fireplaces... Read More »
Now I'm going to discuss the difference between the construction of several amps, not just the insides which we've talked about for the last three types of amps but the actual construction of them. Now there's two main types of amplifiers. There's a... Read More »
pop up camper fridge replacement pamelajo1 Electrical 2 08-08-2009 04:39 PM
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 6 07-27-2009 05:02 PM
Anyone ever paint a fridge? BioHazard Interior Decorating 16 03-02-2009 03:47 PM
Hotpoint freezer cool fridge too cool Maddyrosedad Appliances 1 02-19-2009 07:38 AM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 11:55 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
