Tips For Hardwood Removal Glued To Cement Slab. - Flooring - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 11:26 PM   #1
Tips for hardwood removal glued to cement slab.
Need guidance on removing engineered hardwood floor in our living room that is glued down. Floor cannot be refinished an needs to go! Have to get all the wood and glue up so we can lay tile; what is the best way to do this?
rasberry is offline   Reply With Quote
Old 07-13-2011, 11:40 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There is no easy way to do it.
Your best bet is to buy a "heavy bar" (floor scraper) and go after it. Home centers sell scrapers that allow you to stand up and scrape the floor, in most cases the scrapers are weighted to improve impacting the flooring material. Just depends on how well the flooring was glued down to begin with.
XXX
Old 07-14-2011, 08:21 PM   #3
woodman58's Avatar
The easiest way to remove glued down wood from concrete is to use a saw zaw with a 12" wood blade. The blade flexes enough to lay it flat on the floor and get under the wood and cut it away from the concrete. You can then remove the rest of the glue with a razor scraper.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
Bud Cline (07-14-2011)
Tips for using concrete slab as finish floor? dwoloz Flooring 3 12-08-2010 12:12 AM
Gluing greenboard to cement wall... tips? AdamB5000 Remodeling 5 03-31-2008 11:11 AM
Radiant Heating on Cement Slab can'tdecide Flooring 2 08-21-2007 01:59 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
tips for old gas line removal? Dusty Plumbing 13 10-24-2006 10:40 AM
