Tiling Tub Surround - Flooring - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 12:17 PM   #1
Tiling Tub Surround
My existing walls are not plumb. I'm installing a new whirlpool tub but the flange doesn't touch at every stud. It would be easier to put a shim where it isn't touching but I'm concerned I'll have the same problem when I go to install the cement board and tile. Should I just sister studs or is there a better way?
What would you do?
MikeyP is offline   Reply With Quote
Old 01-04-2009, 12:32 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
FYI:
Tub vs Wall
Angus
My Albums
angus242 is offline   Reply With Quote
The Following User Says Thank You to angus242 For This Useful Post:
Fixif (08-02-2016)
Old 01-04-2009, 12:35 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can add lattice strips to the studs and shim them as required. This way the wallboard will lap the tub flange and should be placed to within 1/8" of the tub surface, same goes for the tile. I would suggest you waterproof the wallboard (assuming there is a shower involved) to eliminate the need for the required vapor barrier behind the wallboard.
Old 01-04-2009, 12:41 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
WHOAH!
Why are there two identical threads running?
Mikey you think your lost now, just wait and see how confusing it's gonna get with two threads running.
How about you make a choice as to which thread to continue with and we'll abondon the other one!
Old 01-04-2009, 12:42 PM   #5
I don't know how to waterproof. Can you explain more? I was going to use the black grainy backerboard. I think it's called cement board but I might be using the wrong term
Old 01-04-2009, 12:44 PM   #6
I put it in plumbing first. I'm continuing with this one only.
Old 01-04-2009, 12:53 PM   #7
angus242's Avatar
Yes, there are actually 3 threads. If a mod reads this, is there anyway you can combined them? I suggested asking a mod to move the original but a new one was started.
Tub vs Wall
Tile Surround
Angus
My Albums
Old 01-04-2009, 03:48 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Mikey you hop around like a ping pong ball!!!
Waterproofing is as easy as painting. In fact there are liquid waterproofing products you can use to paint-on. Look for RedGard, Home Depot has it. You can also get Mapei HPG at Menard's. Lowe's sells Laticrete Product 9235 and also Laticrete Floor and Wall Waterproofing. They are all the same thing and all good products.
Don't think there are any black backerboards but they are dark gray - close enough. There are many tile backer boards available not all made of cement. You could use Durock or Wonderboard or PermaBase or Hardiebacker or Denshield or Green EBoard. the list goes on. Just buy the first one you come to and don't over think it.
Old 01-04-2009, 08:29 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 422
Mikey,
Since yours is a fiberglass whirlpool tub, can you give us the name and model? Will this surround also be used as a shower?
Jaz
Fireplace surround tiling Ducowti General DIY Discussions 8 10-28-2008 09:16 AM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 04:14 PM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
What to do with area about tub surround? geowoman Remodeling 7 05-05-2007 01:56 PM
