Tiling Steps With Curved Corners - Flooring - DIY Chatroom Home Improvement Forum
Old 05-12-2013, 06:33 PM   #1
Tiling steps with curved corners
I am about to tile three steps in the mudroom/breezeway. The steps have curved corners that I plan to square off. I was planning on putting a couple screws into each corner, sticking out a bit. Then put the vertical tile in. Once the tile sets, I would put some thick concrete in the gap, let it cure, and install the horizontal tile. Any input?
sgjordan is offline   Reply With Quote
Old 05-12-2013, 06:35 PM   #2
Another pic
Old 05-12-2013, 08:07 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 288
Hi Jordan, thx for the PM,
You can do it that way, it'll work. I recommend applying some thin set on the step prior to applying the concrete to build up the corners.
You could also place a form in place of the riser tiles, then remove the form. Again use the thin set cuz concrete will not bond to concrete very well. Or you might consider using Quikrete Quick Setting Cement # 1240, read about it here; http://www.quikrete.com/PDFs/DATA_SH...ent%201240.pdf
Jaz
Old 05-12-2013, 08:32 PM   #4
Thanks Jazman, you are the man!
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 04:10 PM
Wood flooring over curved concrete steps floridagirl73 Flooring 11 02-20-2012 01:58 PM
tiling tub surround -- how do I reach the upper corners? Alix Tiling, ceramics, marble 0 06-05-2011 02:05 AM
tiling steps lushie Tiling, ceramics, marble 3 04-25-2011 04:51 PM
Refinishing Oak Steps - How do I fix steps with worn corners trshafer Flooring 2 03-09-2011 11:05 PM
