Tiling A Small Entrance Way, Found Some Moisture - Flooring - DIY Chatroom Home Improvement Forum
Old 08-31-2012, 04:17 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 508
Tiling a small entrance way, found some moisture
I originally was going to tile over the existing whereas the height would be no issue. When I tested the tiles for bond strength, they pulled right up. I cannot identify what is on the floor and the bottom of the tiles - I can't tell if it's the remnants of some laminate flooring they tiled over, or the stained, dried thinset. The underlayment is the concrete basement floor - this is a split level.
I tore up all the tiles and I will tile over the concrete. I did find a tiny bit of moisture, tiny little beads of it, under the floor in some places. I'm not sure how to proceed. This area is a simple 25sq ft area between the garage entrance and my downstairs family room which is carpeted. Should I just seal the floor and tile?
J187 is offline   Reply With Quote
Old 08-31-2012, 07:17 PM   #2
DIY staff
Rewards Points: 7,174
It looks like you have a black ,tar like , adhesive---cut back---how old is that house?
If it is cut back--you need to make a modified thinset by mixing unmodified with a liquid latex.
Kerabon and Keralastic by Mepei is a good example.
Bud Cline wrote an excellent piece on thinsets--"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
notmrjohn (09-02-2012)
Old 09-01-2012, 11:45 AM   #3
J187's Avatar
Rewards Points: 508
House was built 1961. How can I tell if it's cutback? So you think that perhaps someone tore up a vinyl floor that had cutback and then tiled right over the cutback with thinset?
Old 09-01-2012, 11:47 AM   #4
DIY staff
That's what it looks like to me----if the correct thinset is used--no problem---if not --the tiles can pop off easily
Old 09-01-2012, 01:19 PM   #5
J187's Avatar
Rewards Points: 508
I see. Thanks. So is this the same modified thinset I'd use for tile over tile?
Old 09-01-2012, 11:26 PM   #6
DIY staff
You would be safe using the two part for tile over tile--although a good quality modified will also work.
Whenever I face a possible bonding challenge I use Kerabond and Keralastic (or something similar) Just good insurance.
Old 09-02-2012, 12:58 AM   #7
Bombastic Idiot
notmrjohn's Avatar
Oh man! The timing was perfect, I can even see the puzzlement on your face, then the disbelieving realization.
I remember "helping' dad lay floors when i was a lad in late 50's early 60's. that stuff was nasty. He'd finally send me out to wait in the truck, so's I wouldn't be tracking it all over, he didn't need me to hand him tiles for a while. " How'd you get it on the front door, when did you go over there?"
Thanks ,mike, I'm still laughing.
But wait, "tiny little beads of it (water) under the floor." but as I remember the sweat from Dad's forehead would bead up on that stuff. I think the water could have come from topside and not seeped up. Funny thing, the longer I helped Dad, the more he would sweat, you'd think it would be the opposite.
Tar like... noooo could it be? Oh man. Thanx.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
The Following User Says Thank You to notmrjohn For This Useful Post:
oh'mike (09-02-2012)
Old 09-03-2012, 07:41 AM   #8
J187's Avatar
Rewards Points: 508
Thanks. Some 747 and a razor scraper made pretty quick work of it. Down to pretty much bare concrete now.
Where to find bulk small wire? Red Squirrel Electrical 13 06-14-2012 10:38 PM
Small white sacks found on wood beams tcook555 Pest Control 6 04-17-2012 01:11 PM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Moisture mystery in midst of shower redo Hisgirl Remodeling 3 01-05-2009 10:29 AM
No Moisture Barriers 1parkpointer Roofing/Siding 4 12-11-2008 07:44 PM
