Tiling In A Shower - Flooring - DIY Chatroom Home Improvement Forum
Old 04-06-2011, 11:25 AM   #1
Tiling in a shower
I am being asked about a product called DensShield,
anyone have any experience with this product in a shower installation?
I am strongly suggesting he uses Durock or wonderboard as a backer for the tiles with kerdi as a water membrane. He wants to go with DensShield with no waterproofing membrane, just tile direct to the backer.
Even with cement board I am strongly suggesting he uses a waterproofing membrane.
I am always up to hearing any and all opinions on the subject.
Mike159 is offline   Reply With Quote
Old 04-09-2011, 10:43 AM   #2
denshield is a good product. easy to cut and install. i have used it in showers alot. do not use a vapor barrier behind it (manufacturer's instructions). Tape seams and corners. as far as waterproofing the surface of denshield, I personally do waterproof it . (The corners, seams, and slight recesses caused by the screw heads). i estimate i have used denshield for 8-9 years with no failures. (SO FAR!)
acglobal is offline   Reply With Quote
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Tiling a shower wall cm3putter Building & Construction 1 11-23-2009 02:32 PM
Tiling Stand Up Shower IlliniGuy Kitchen & Bath Remodeling 3 06-04-2009 12:10 PM
Tiling over greenboard outside shower area toocheaptohire Remodeling 4 04-10-2009 08:42 AM
Tiling over plastic shower base newproject Building & Construction 5 02-21-2009 07:40 PM
