Tiling A Patio That Already Has Screen Enclosure. - Flooring - DIY Chatroom Home Improvement Forum
Old 04-03-2010, 10:10 PM   #1
Tiling a patio that already has screen enclosure.
Hello! I am a long time lurker, and have learned a ton from the forum already. I now have a new project and question, which I have not found the answer to yet, so I thought I would post it here.
I have a 12'x10' covered patio, the house roof extends over it. The sides are open but enclosed in fiberglass screen, using aluminum screen enclosure framing. The framing and screen extend from floor to ceiling. At the bottom (floor), the frame is about 1 inch thick and is bolted into the concrete.
My home is in Fort Myers, Florida, so there is no real freezing problem.
I would like to tile this patio. I have tiled indoors before. I have one main question about this project.
How do I deal with the "edges" of the patio. Do I tile up to the aluminum frame, or do I remove the frame, tile underneath, then reinstall the frame on top of the tile, but cut the screen and side framing shorter?
The former would be less work, but I don't know how that would affect drainage of the small amount of water that gets onto the patio during windy rainstorms.
Anyone have any ideas and opinions? I'd appreciate them, and any other tips on this project.
Thanks in advance!
gggonzalez is offline   Reply With Quote
Old 05-01-2010, 11:12 PM   #2
Well, my father has suggested to simply tile up to the edge of the aluminum framing, leaving a grout line along the edge, but filling that with water proof caulking. I am going to give this shot over the next few days, hopefully it turns out...
Old 05-02-2010, 10:25 AM   #3
if the screen channel at the patio drains now you could tile to 1/4" of frame and leave open with no caulk for drainage. or seal edge to frame and if enough room drill weep holes in frame
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
olzo55 (07-04-2014)
Old 07-04-2014, 06:25 PM   #4
Smile
Try pool cage plus for perimeter screenwall drains ... also available on line or Ace Hardware.
jim wilson is offline   Reply With Quote
Old 07-05-2014, 10:24 AM   #5
Rewards Points: 3,834
Post is 4 years old, I would guess he has it tiled by now.
Canarywood1 is online now   Reply With Quote
Tags
outdoors , patio , tiling
Aluminum Patio Enclosure Roof Leaking baileyd Roofing/Siding 6 03-25-2012 10:05 PM
Tiling a shower enclosure - questions re: hardiebacker & wall prep DyerWolf General DIY Discussions 10 01-15-2009 11:10 AM
heating options for a patio enclosure tarheelblue HVAC 6 11-17-2008 02:38 PM
sliding screen double patio doors bcrest General DIY Discussions 1 10-22-2008 07:04 AM
Tiling over tub enclosure dumbunusedid Remodeling 3 07-29-2008 01:37 PM
