Tiling A Patio - Flooring - DIY Chatroom Home Improvement Forum
Old 04-07-2011, 01:27 AM   #1
tiling a patio
I have a small outdoor patio on the second floor. I plan to lay tiles on it. How do I choose what kind of tiles to use? The place I live is in Pleasanton, California. Hot in the summer, rainy and cold (frost possible) in the winter.
Thanks in advance
loolooya is offline   Reply With Quote
Old 04-07-2011, 05:40 AM   #2
DIY staff
Rewards Points: 7,174
What is this 'Patio' made of? Is it concrete?
Old 04-07-2011, 11:14 PM   #3
The patio is made of wood. I think there's a layer of plywood, and then a layer of metal (like on the roof), and put some cement on top.
Old 04-08-2011, 04:49 AM   #4
DIY staff
I doubt that that can be tiled successfully---post a picture or two,please.
Old 04-10-2011, 02:37 PM   #5
Do you mean that the floor has too be very sturdy to tile? It makes sense. If the underlining is soft, then the tiles will all become loose after a while. Is that what you are thinking?
Yes, the patio as of now is kind of squashy. You can feel that some part is soft.
Thanks.
Old 04-10-2011, 04:08 PM   #6
DIY staff
Tile needs a very stable base. Out door tiling over a wood structure is always a challenge----
Humidity and heat cause even a strong structure to move----
The tiles must also be set over a waterproof bed---tile and grout are not water proof---water must be kept from reaching the wood structure in order to keep the wood from swelling and dislodging the tile work.
----Mike-----
Old 04-10-2011, 06:46 PM   #7
Veteran Rehabber
Why Tile?
---Tile needs a very stable base. Outdoor tiling over a wood structure is always a challenge---
Do you need to tile? I've found & used walkable roof membranes for small flat roof projects. Google 'walkable roof membrane' and you will get several products on the first page.
CMHbob is offline   Reply With Quote
Old 04-11-2011, 12:09 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I smell a rat!
XXX
Tiling a patio that already has screen enclosure. gggonzalez Flooring 4 07-05-2014 10:24 AM
Patio tiling injvstice Tiling, ceramics, marble 3 11-03-2010 05:01 PM
Tiling Outdoor Patio Branden Flooring 2 06-23-2010 10:24 PM
Tiling over cement patio Clemey Tiling, ceramics, marble 3 06-13-2010 05:07 PM
Tiling Over Aggregate Patio patch Flooring 2 03-18-2010 07:13 PM
