Tiling Over Wood Subfloor? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-01-2009, 01:55 PM   #1
I am looking to see if it is acceptable to tile directly over a pre-existing plywood that has been previously used as a floor backerboard.
The bathroom floor construction is ¾” tongue and groove sub floor in decent shape and ½ plywood on top of that. Making the total floor 1 ¼” thick and quite solid.
The ply wood has a slight amount of what looks to be mastic / glue left over from the original tiles.
Can it tile directly on to this plywood, and if so how would this hold up. (at least compare to a standard cement board situation)
P.S. I also don’t want to remove the plywood backer board and replace it with concrete board because it has like 1000 nail holding it down.
Any suggestions are welcomed.
bz2005 is offline   Reply With Quote
Old 04-01-2009, 09:07 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 220
Not knowing what type of tiles were there or what type of mastic, the safe thing is to install 3/8" or thicker underlayment plywood, then install a membrane such as Ditra or Noble's CIS. This saves you height problems. Ditra is 1/8" installed and CIS is thinner.
Although people have tiled direct on ply, (with some success even), the method is only possible on floors in dry rooms.
Jaz
Old 04-01-2009, 09:22 PM   #3
Just sold a tile repair job a few days ago that applies to this subject.
The original installer put the tile direct to plywood. Right outside the shower, the tiles started to come loose.
Over the years, every time someone got out of the shower with wet feet, a little water would seep through the grout and this delaminated the plywood to which the tile was bonded.
I like Jazman's suggestion about the Ditra or similar products... have long been a Schluter fan.
If the existing doubled-up decking is nice and solid with no noticeable deflection, I'd probably feel safe going right over that with the Ditra.
Mudd is offline   Reply With Quote
Old 04-02-2009, 11:14 AM   #4
Tiling over Wood Subfloor
This is sort of what i figured the combination of the slightly wet conditions in a bathroom and the limited success of tiling on plywood makes it best to remove of old 1/2" plywood subfloor.
I started messing with the hundreds or so nails holding the subfloor down and they seem to be removable.
Now, I plan in using basic 1/2" or 5/8" cement board over the ¾” tongue and groove sub floor and fiberglass tape & thinset the joints, and then thinset the 2"x2" (12"x12" sheet) glazed porcelain tile down over that. Making the floor about original height
I don't plan on water sealing the walls to the floors to the walls, (I expect water just not a ton)
Does this sound like a solid plan?
Would you recommend any different?
Tags
bathroom tile question
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Subfloor moves (wood) and want to install travertine scorpion693 Flooring 4 02-27-2009 07:38 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
