Tiling Over Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 06:31 PM   #1
Rewards Points: 212
Question
Tiling over tile
what is involed in preparation in tiling over tile?
bluebird5 is offline   Reply With Quote
Old 03-02-2011, 07:08 PM   #2
DIY staff
Rewards Points: 7,174
If the tile is soundly attached (that's a big IF)---(you do mean ceramic over ceramic,Right?)
Scuff up the glaze--I suggest a 4" grinder with 80 grit paper( two sheets-back to back)
Then set the tile using unmodified thinset mixed with liquid latex--Kerabond and Keralastic is a good choice--
That's it.
Removing old floor coverings is always the best method---your new work is going to be riding on what ever you are going over. I suggest tile over tile only in rare situations.---Mike--
Old 03-02-2011, 07:39 PM   #3
Rewards Points: 212
thanks mike
Old 03-02-2011, 08:04 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 422
I have no problem tiling over tile if the old floor is is good shape. I have done it many times through the years including one of my own bathrooms. Also for a very close friend of the family who live just down the road a piece.
Both of these jobs can be seen by browsing these galleries One is titled Kerdi shower over plywood floor. http://picasaweb.google.com/tile4youinc
Jaz
Old 03-02-2011, 08:26 PM   #5
Rewards Points: 212
jazman how do you do your kerdi. some guys say they do it like a roof and go from the bottom up, but the schluter video shows the floor going in last. does it seal any way you put it?
Old 03-02-2011, 08:35 PM   #6
Rewards Points: 212
back to the original question jazzy, is a grinder and some 80 grit how you prepare you tile when you tile over it? what kind of thinset do you use?
Old 03-17-2011, 04:35 PM   #7
If the tile is good no prob.. But you can also get a interlocking tile that you can set over the tile. You would need a foam underlayment and then you can go over what you have.
JohnRocks is offline   Reply With Quote
Old 03-17-2011, 07:43 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 422
HUH? I see, so foam, then ceramic tiles? OK!
Jaz
Old 03-17-2011, 09:58 PM   #9
Aged Sleeper
Bken's Avatar
Cool
I would recommend getting a good foam like the 1/8" with a foil mositure barrier or a recycled rubber underlayment. These seem to work really good on the interlocking tiles. The rubber can also be used on glued tiles.
Bken is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
tiling - difference in thickness. glass tile vs porcelain jbitt Kitchen & Bath Remodeling 2 06-13-2010 02:22 PM
Tiling over an existing tile floor Britinva Flooring 9 02-14-2010 01:00 PM
bath room tiling question, laying tile around a curve everyman Kitchen & Bath Remodeling 2 02-14-2009 01:21 PM
Tiling Shower: Decorative tile thicker than Wall tile digexpressions Remodeling 11 06-08-2008 05:49 PM
