Tiling Over Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 02-28-2008, 11:02 AM   #1
tiling over tile
hi, will i have problems putting 500 sq ft of tile over a glossy faced tile? if not do i need to put an addittive in the thinset help!!
thanks tom
tnttom25 is offline   Reply With Quote
Old 02-28-2008, 04:34 PM   #2
Tile Contractor
Bill_Vincent's Avatar
Hi Tom-- Before doing something like this, you want to check that entire floor, and make sure there are no cracks in either the tile OR the grout. You also want to take something like a butter knife, and tap that whole floor out to make sure there are no hollow spots. So long as everything comes back the way it should, then take a belt sander and rough up the face of the tile to give the thinset a little more to bite into. For thinset the ONLY thinsets I'd recommend are unmodified thinsets mixed full strength with a liquid latex additive to make sure you get a good strong bond. Something along the lines of Laticrete's 317 thinset mixed with their 333 additive, or Mapei's Kerabond thinset mixed with their Keralastic additive, or Hydroment's Tilemate thinset mixed with thier Flexalastic additive.
"Whether you think you can, or you think you can't, You're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
How scuffed should old tile be before tiling over w/ new J187 Flooring 3 07-25-2006 09:01 PM
Tiling questions with pictures. J187 Flooring 11 07-18-2006 08:24 AM
