Tiling Over T&G - Flooring - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 10:20 AM   #1
Rewards Points: 115
Tiling over T&G
What's best practice before laying down tile?
This is what I'm dealing with. How do I ensure I have a nice and isolated, level area to lay tile? The T&G is 1" thick.
Uploaded with ImageShack.us
Didymus21 is offline   Reply With Quote
Old 06-02-2012, 03:14 PM   #2
Remodeling Contractor
Cover this with 3/4" plywood and then 1/4" cement board
The Following User Says Thank You to Bob Mariani For This Useful Post:
oh'mike (06-02-2012)
Old 06-02-2012, 05:36 PM   #3
DIY staff
Rewards Points: 7,174
Bob has it----natural wood moves a lot--top that with BC exposure one plywood--1/2" will do--3/4" is better--then lay on a cement board 1/4" set in thinset and nailed or screwed--now you have a good safe base for tile.
If you will give us the joist size--spacing--grade(if youcan find that) and the unsupported length--someone here will check the joist deflection and let you know how strong your floor system is--
Old 06-02-2012, 07:11 PM   #4
Rewards Points: 115
Wow, guys, thanks! The joists are roughly 3.75"X7" and they are spaced every 52." The previous owner put 1/4 cement board right over the tongue and groove.
Old 06-02-2012, 07:29 PM   #5
Rewards Points: 14,312
Undersized floor joist, over double the normal spacing, anyone else think tile is a very bad idea?
Old 06-02-2012, 07:50 PM   #6
Rewards Points: 115
Really? It has supported a cast iron bathtub the last 45 years without issue...
Old 06-02-2012, 07:58 PM   #7
DIY staff
Double check that 52" number--I see rows of nails every 16" or so in the picture.
Also those joists--how long is the unsupported span? Measure from the foundation to the center beam if it's the first floor--or outside wall to nearest supporting wall.
Old 06-02-2012, 08:13 PM   #8
Rewards Points: 115
Maybe these will clear up some of the confusion about spacing.
I guess I'm confused....isn't the distance between joists going to be the same thing and the largest unsupported span? It's a ranch style home. I believe the exterior walls are the only supporting walls.
Old 06-02-2012, 08:33 PM   #9
DIY staff
Sorry I questioned you---you are seriously over span for tile---
The tongue and groove flooring may flex to much over a 52" joist opening--use the 3/4" ply and realize that this floor will be a risk---
Old 06-02-2012, 10:06 PM   #10
Rewards Points: 115
Am I correct in assuming the risk is only that I may have cracked grout lines/tile in the future? Or, is the weight risking my subfloor integrity?
Old 06-02-2012, 10:13 PM   #11
DIY staff
Your house is fine--the floor system might be to flexible for a 'guaranteed not to fail' tile job.
If you don't mind taking a risk--tile it--you may be just fine--if it fails--next time use hardwood or aanother floor covering that can take some movement of the floor.
Didymus21 (06-02-2012)
Old 06-02-2012, 10:27 PM   #12
Rewards Points: 115
Appreciate all the help. I have 3/4 Top Choice Oak Hardwood plywood pieces left over from another project. Would these be OK to use? I'm just trying to get rid of it at this point.
This stuff: http://www.lowes.com/pd_59298-99899-...7C1&facetInfo=
I see now it says for interior use....so I'm thinking probably not... Would pressure treated plywood be overkill?
Old 06-03-2012, 05:45 AM   #13
I think that the only way to even think that this would work would be to go underneath, put blocking every 16 inches (2 x 10) then install 3/4 t and g plywood, ditra then tile. You really don't want dimensional lumber in the equation as a subfloor. It would be nice if you could remove it and replace with plywood. I am not sure how much trouble that would be for you.
farmall is offline   Reply With Quote
The Following User Says Thank You to farmall For This Useful Post:
oh'mike (06-03-2012)
Old 06-03-2012, 05:49 AM   #14
DIY staff
You need exterior glue---so buy bc exterior--
Farmall has a good suggestion---
Old 08-13-2012, 02:18 PM   #15
Rewards Points: 115
Based on the attached pictures, could someone explain (like you are talking to a two year old) exactly how I would block this to make it a little more stable for tile? I see what Farmall wrote, but I'm a visual person and I'm having trouble picturing it...so I'm stuck.
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 08:37 AM
tiling over painted T&G kurtp2 Flooring 15 09-15-2011 09:28 PM
unstable subfloor for tiling hohadcr Flooring 2 08-27-2010 12:10 AM
First tiling project, need some help DIYD Tiling, ceramics, marble 1 08-06-2009 06:15 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
