Tiling Over Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 08:44 PM   #1
GBunny
Rewards Points: 71
Tiling over subfloor
Can you tell me whether it is ok to tile directly onto the sub-floor with mesh and cement? Does the building code require another layer of plywood over the sub-floor?
GBunny is offline   Reply With Quote
Old 11-29-2010, 09:24 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Hi Bunny,
I think you meant to say lath and thin set. I do not believe your local building department has an opinion on that method, or even cares how floor tiles are set.
It's called "scratch-coat" and "Jersey mud job", and I can tell you it's a terrible method. It has failed every test it's been subjected to when done under controlled conditions. However, it is very popular in your area of Canada. Why do many tile jockeys do it that way? It's easier and cheaper to do.
Results? You're likely to have hairline cracks in the grout within the first season, (but may not know it). Long term,..... high failure rate can be expected.
If you wanna do it right let us know.
Jaz
unstable subfloor for tiling hohadcr Flooring 2 08-27-2010 12:10 AM
Tiling over shiplap subfloor Catahoula Tiling, ceramics, marble 2 04-24-2010 12:30 PM
Tiling, Subfloor, backerboard????? mablack1970 Flooring 5 02-17-2010 07:55 PM
Tiling Over Wood Subfloor? bz2005 Flooring 3 04-02-2009 10:14 AM
preparing for subfloor before tiling zazu2056 Flooring 1 10-29-2005 08:09 AM
