Tiling Over Sprayed On Flooring. - Flooring - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 01:08 PM   #1
Tiling over Sprayed on Flooring.
My husband and I own a campground and want to do some improvements in the laundry room and bathrooms. It's a cement base floor with some sort of sprayed on coating (possibly vinyl?) The building was constructed in the 70's if that helps to identify the floor. We want to tile the floors. Will we have to try to scrape up the coating - not an easy task, I'm sure. Or can we just tile directly over the coating.
Appreciate any advice.
Donna
hulawho is offline   Reply With Quote
Old 08-12-2012, 02:23 PM   #2
from the limited knowledge i have gathered in the past if the surface isn't porus enough for water to soak into it in a short time then the thinset will not stick to it either. usually you would have to remove the coating and then lightly grind the surface so the thinset will adhere. i am sure other more knowledge people will reply.
Old 08-13-2012, 06:21 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
You really need to know what the coating is. There are products like Mapei Eco Prime Grip that can prime over stuff like epoxy and tile right over it. But if it's something with a silicone base you could be in for a lot of work removing it.
Darkling Designs
poppameth is offline   Reply With Quote
The Following User Says Thank You to poppameth For This Useful Post:
oh'mike (08-13-2012)
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-19-2012 12:51 AM
tiling over vinyl flooring? djhaleah Flooring 1 06-18-2011 01:03 PM
Tiling - What makes the proper flooring sandwich? luvdairish Remodeling 13 11-09-2010 11:46 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
