Tiling Over The Outdoor Kitchen Countertop - Flooring - DIY Chatroom Home Improvement Forum
Old 06-16-2011, 11:32 AM   #1
Tiling over the outdoor kitchen countertop
Hi & thanks for looking at my post.
I am in the process of deciding on how to tile my countertop of the outdoor kitchen/bbq. Over the period of time, the thing slowly grew into a 17' X 9' monster
At the bottom of the "cabinet" i have a 6" wide footrest that will be receiving a quartzite trim on top of it. Trying to figure out how to "tile" the apron of the countertop. I've been recommended a Schluter Systems as a trim piece around the top edge of the countertop, but...
Looks like even if I use the Schluter, although it's gona cost me an arm and possibly a leg considering my 17' length just on one side of the bbq, I will still need to add tile pieces under the trim to finish it off. Since I will be using quartzite stone (~1/2") on my footrest of the bbq, I would like to "tie it in" together with my countertop.
My questions; - Is it feasible/doable to incorporate the quartzite pieces, like whatever I have as leftovers from my footrest into the apron? My apron is most likely will be built from a 2x4 (maybe two of them) flatside under my counter with cement board pieces on the faceside and the bottomside of it. If I extend the bottomside piece of the cement board past the front of the 2x4 enough to accommodate for the thickness of the quartzite. Am I giving enough of the support to the quartzite? Can I use modified thinset to permanently "glue" the quartzite pieces to both the apron and the footrest of the bbq?
Thanks,
nmikmik is offline   Reply With Quote
Old 06-16-2011, 04:23 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Two questions:
1. Where do you live?
2. Is Quartzite suitable for outdoor use?
XXX
Old 06-16-2011, 07:52 PM   #3
Thanks!Q
and the answers:
1. San Diego - CA
2. Quartzite is suitable for the outdoor use - at least i've been told that it is.
Old 06-16-2011, 08:08 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay good deal!
1. San Diego - CA
No freeze/thaw issues.
I would think that would be okay also in that are.
I'm not sure what you mean by "apron" but yes you can do what you suggest as far as I can see. I would however use a high powered thinset mortar because of the outdoor use and the temperature swings even tho they aren't drastic.
I'm not sure what Schluter product you are considering, that may change the type of thinset required. I don't see where Schluter products are really that costly when you consider what they do and some of the pitfalls of the alternatives.
XXX
Old 06-17-2011, 09:57 AM   #5
Thanks again for your answer!
The "apron" I am referring to is that thin (er) piece of the contertop that goes around the perimeter of it or just the face of it, depending if it's on the regular cabinet or the island type of a cabinet. Basically the thin piece of a trim covering the countertop substrate. I am sure there are other names for it, I just heard that one used.
As far as Schluter, the cheapest $46 for a 8' piece of stainless, of what I think need -
http://www.schluter.com/2_8_rondec_step.aspx
I was thinking of using 2.25" width to cover my plywood and the cement board on top of it.
To do a perimeter of my island I'll need to spend at least $350 and that will not include the corner pieces, that I most likely end up needing because the straight piece will never bend the "right" way.
I am willing to spend it, but it will not give me that "tied in" look that I am looking for, as the pieces of the Quartzite will - I think.
And I just realized - how stupid I am. I can not exted the cement board past the front of my 2x4 like I was planing here "cement board pieces on the faceside and the bottomside of it. If I extend the bottomside piece of the cement board past the front of the 2x4 enough to accommodate for the thickness of the quartzite."
Otherwise I will have the same issue of covering the cement board piece with another trim.
Omnigrip adhesive for tiling kitchen countertop? tforse Kitchen & Bath Remodeling 3 04-29-2011 07:33 PM
A few tiling questions - floor, tub, and countertop benr Tiling, ceramics, marble 5 04-13-2011 05:15 PM
tiling above an un-level countertop pattyo Kitchen & Bath Remodeling 1 02-22-2009 11:24 PM
Procedure for tiling countertop sgtrock Remodeling 6 01-08-2009 01:37 PM
Tiling bathroom floor and countertop: Backerboard needed? digexpressions Flooring 2 03-04-2008 05:38 PM
