Tiling Over Old Peel And Stick Adhesive. - Flooring - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 02:09 PM   #1
Rewards Points: 14
Tiling over old peel and stick adhesive.
This question has been asked by others, but with slightly differant circumstances.
I have a half bath in my basement with Armstrong peel and stick tiles directly on the concrete.
The tiles seem like they will come up easy from the first couple I saw.
I've been told that I should use a chemical cleanup, but I'm not fond of that idea with a 2 year old in the house with that type of fumes, etc.
What are my best options?
Other things I read was to use a thinset type mortar with an additive to promote better adhesion to the ceramic/porcelin tile.
Is this the proper route?
Thanks in advance for your help!
-Mario
m3rdpwr is offline   Reply With Quote
Old 04-16-2012, 03:43 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
-Mario
Putting a skim coat over it with thinset, there is a liquid milk type you can add if you want. That might be better bet.
JetSwet is offline   Reply With Quote
Old 04-17-2012, 06:32 AM   #3
DIY staff
Rewards Points: 7,174
No chemicals--they will soak into the slab and cause bonding problems--You have two choices that I know work---
The easiest is to use a two part thinset (thank you Jet swet) Kerabond and Keralastic is a good example--
Or encapsulate it with a self leveling compound---once again, a two part--powder and liquid latex is the safest bet---Jifset and Linewebers liquid is a popular brand--
JetSwet (04-17-2012)
Old 04-17-2012, 11:35 AM   #4
Rewards Points: 14
Thank you both!
Old 04-17-2012, 01:30 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 288
In addition to the above info, check out this product from Mapei.
http://www.mapei.com/public/US/produ...rip_TDS_EA.pdf
Remember that residue from peel & stick tiles is not cut-back.
Pay special notice to;
"Use over substrates that have a residue of well-bonded cutback adhesive, floor-covering adhesive or polyurethane adhesive."
Notice that while the other products might work over a residue, (film) of cut-back, this new product claims to also work over other types of adhesive residues.
Personal note. Many years ago I removed VAT installed with clear brush-on adhesive from my basement furnace/storage room. I used either a pre-blended modified thinset or a regular dry-set mixed with the appropriate latex additive. All seems fine for a few years, later the bond of the entire room failed. Being a utility room they are still there and look ok. But tap one and you'll hear they are there because of gravity and the grout.
Later, while checking other products I came across a note from TEC that their modified mortar may work over cut-back, (with proper prep), but not to use them over adhesives that were tacky. Peel & Stick adhesive residue is tacky. Make some calls, and read more.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
m3rdpwr (04-17-2012)
Old 04-17-2012, 01:46 PM   #6
Rewards Points: 14
Thanks JazMan,
Lowes near me sells MAPEI, but not that product.
I'd have to drive about 20-25 miles to get it at Lumber Liquidators or other flooring store.
-Mario
Old 04-17-2012, 02:09 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 288
That's great if you found someone who has it. Or you can grind the floor down. Did you check, are you saying LL has that product? That would be strange.
Wonder what qualifications & experience the person who told you to use chemicals had?
Jaz
Old 04-17-2012, 02:41 PM   #8
Rewards Points: 14
Jaz
According to the MAPEI website, they carry it.
Whether in stock or not is another question.
The chemical was a tile guy with experience who worked at Lowe's.
He hadn't steered me wrong on other things, but has since left.
What a pain!
Maybe I'll just put stick tile back in.
Old 04-17-2012, 09:17 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 288
WHAT?
You give up too easy.
Jaz
Old 04-18-2012, 10:22 AM   #10
Pro
JetSwet's Avatar
Rewards Points: 502
What a pain!
I wouldnt give up that easy just because the guy at lows isn't there. The guys on this forum are well knowlaged and have been down this road with op like your self many of times.
Old 04-18-2012, 10:25 AM   #11
Rewards Points: 14
I realize and appreciate everything.
Just trying to find who has the product and getting it is going to be a pain.
-Me
Old 04-18-2012, 11:02 AM   #12
Pro
JetSwet's Avatar
Rewards Points: 502
-Me
Call lows and ask if they have the mapei latex additive before going out there.
Old 04-18-2012, 11:06 AM   #13
Rewards Points: 14
They don't sell the primer JazMan mentioned.
They are only around the corner from me, and don't recall seeing that primer.
The additives they do sell for the thinset/mortar, but I was hoping to put down that primer first.
-Mario
Old 04-18-2012, 11:29 AM   #14
Pro
JetSwet's Avatar
Rewards Points: 502
-Me
Old 04-18-2012, 11:42 AM   #15
Tileguy
JazMan's Avatar
Rewards Points: 288
That primer may not be easy to find, might have to order it. Maybe Dal Tile? We don't know where you are since you forgot to insert your location in your profile.
I would call Mapei to see if they can tell you who has that product. I would also ask their technical department if they recommend their Kerabond mixed with Keralastic for this purpose.
If you have a technical question, call 1-800-992-6273 (U.S. and Puerto Rico) or 1-800-361-9309 (Canada) to speak to a Technical Services Specialist for your type of flooring project.
Jaz
m3rdpwr (04-18-2012)
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 06:30 PM
Peel and stick on painted concrete? polarzak Flooring 8 12-23-2011 02:13 PM
peel and stick adhesive trump Flooring 1 04-03-2011 10:21 PM
Removing peel and stick tile adhesive in preparation for tile stubborn1 Flooring 3 01-09-2011 02:34 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 08:52 AM
