Tiling Over In Floor Radiant Heat - Flooring - DIY Chatroom Home Improvement Forum
Old 03-30-2009, 01:09 PM   #1
tiling over in floor radiant heat
My system is pex installed below the floor between the floor joists. I am getting ready to install finished floors, and have heard that there may be steps needed different from tiling or hardwood floors over a 'non-heated' floor due to the expansion and contraction resulting from the in floor heating. I generally install Durock over the subfloor, and tile on top of that, but it has been mentioned to me that I'll need a? crack isolation membrane to protect the finished project.
Any help would be great.
Laura E
Laura E is offline   Reply With Quote
Old 03-30-2009, 05:55 PM   #2
What do you have for a subfloor now?
Yes, a membrane such as Ditra is a good idea to use over the heating system, no durock needed if this is used.
R&D Tile is offline   Reply With Quote
Old 03-30-2009, 06:40 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Flexible thinsets are also available for such installations.
Old 04-01-2009, 08:38 AM   #4
For subfloors: we have 3/4 osb on half of the area, and 3/4 plywood on the the other half
Tags
flooring
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
Tiling on Above sub floor radiant heat jelly Flooring 14 08-05-2008 01:24 PM
