Tiling Over An Existing Tile Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-13-2010, 03:27 PM   #1
Like to DIY
Rewards Points: 18
Tiling over an existing tile floor
I want to re-tile a bathroom floor. The existing floor tile is 12"x12" ceramic tile, solid surface, been down 6+ years with no cracking.
I really do not want to pull up the old tile.
Under the new tile I want to put a heated wire mat.
So my thinking is to use an appropriate primer on the tile, lay the heated mat, use a self leveling compound and the re-tile.
I'm not worried about the extra height.
So my question is is this feasible - what primer and self leveling compound would be suggested.
Thanks in advance.
Cheers,
Mark
Britinva is offline   Reply With Quote
Old 02-13-2010, 03:34 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not really!
Nobody ever does!
I think this hasn't been thought through all that well maybe
XXX
Old 02-13-2010, 03:47 PM   #3
Newbie Bill
Rewards Points: 522
Best way is to remove old tile first.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 02-13-2010, 06:37 PM   #4
Like to DIY
Rewards Points: 18
Yeah - think I knew answer from the start. I guess I'm going to see how good a job I did with the original tiles. Hope I can get a reasonable surface to work with.
Can anyone recommend a good self leveling compond that will work well over a heated floor mat (likely SunTouch). Be good if was carried by Home Depot or Lowes but I do have some good builders merchants in area.
Cheers,
Mark
Old 02-14-2010, 07:45 AM   #5
Home Depot......http://www.custombuildingproducts.co...er=diy&lang=en
R&D Tile is offline   Reply With Quote
Old 02-14-2010, 09:55 AM   #6
Like to DIY
Rewards Points: 18
Thanks R&D
On reading it indicates a substrate can be existing ceramic tile...... so what are good reasons for not pulling up old tile?
Old 02-14-2010, 10:38 AM   #7
Laziness.
The only defense for going over old tile is to build up height to match an abutting finish floor height.
But even then it's cheating, as the tile should be pulled and replaced with backer board.
Stop your whining, rent an electric demolition hammer, and do it right.
Dairylander is offline   Reply With Quote
Old 02-14-2010, 11:29 AM   #8
Like to DIY
Rewards Points: 18
Originally Posted by Dairylander View Post
Laziness.
Hey after shovelling 60+ inches of snow this winter a fellows got a right tobe lazy now and again
Old 02-14-2010, 11:54 AM   #9
Hah! No pity here! We had over 100 inches last year.
Old 02-14-2010, 01:00 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If the original tile isn't removed the new tile could end up like the snow. "Shovelled"!
XXX
toilet install over new tile floor dbrew Plumbing 11 07-08-2014 08:34 AM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
what sub floor for slate tile? gk02 Flooring 10 02-26-2009 09:49 AM
Tile over existing tile floor? dwalls32 Remodeling 3 07-03-2007 04:19 PM
Floor and wall tile question irlizard Flooring 21 07-20-2006 01:35 PM
