Old 01-28-2009, 04:33 AM   #1
Tiling over different surfaces
I'm just about to get my kitchen done, including the floor being retiled. Following a subsidence problem, the floor level has dropped by about 6mm at one end of the room. The person coming in to do the tiling said that rather than take all the tiles up (there are two layers) he would remove those where the floor begins to decline (about 1/5 of the floor space) so that he has enough depth to concrete and level this area and then to tile over the whole lot so that the floor is flat again. Since I have had an issue with subsidence (hopefully now rectified) I am naturally concerned about any future movement. Will the fact that the new tiles (5 grade porcelain) are going over part tiled and part-concrete floor be a problem? I am just concerned that materials move differently. If this is okay, should he be using some kind of flexible adhesive, etc...?
Looking forward to hearing from you.
Jenny Morgan is offline   Reply With Quote
Old 01-28-2009, 08:55 AM   #2
This described scenario is ill advised at best. All the tile layers should come up. Then the floor prepped for a new floor. What ever that needs.
Ron
Old 01-28-2009, 08:57 AM   #3
Moderator
Termite's Avatar
I can tell you that flexible adhesive is probably the last thing you want. To maintain the integrity of the grout joints and the tiles themselves, a rigid base is needed...Thinset (like mortar) is probably more appropriate.
Personally I would remove all the tiles and use leveling mixture on the floor's low spots.
Moving this thread over to flooring where there are some flooring pros that can help you.
Tiling bathroom ivaiva Project Showcase 3 08-30-2008 09:24 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 04:44 PM
What adhesive to use for tiling wall? sz8 Flooring 4 03-21-2008 06:55 AM
Tiling - what a nightmare Richo Flooring 9 01-06-2008 09:02 PM
bathroom tiling neptunian General Discussion 1 03-29-2005 08:44 AM
