Old 09-09-2010, 01:54 PM   #1
tiling over cutback adhesive residue
I need to tile 60 square feet of concrete that had been covered with parquet tiles. A thin layer of cutback black adhesive remains. It is not water porous. Both Ultraflex 2 and Ultraflex 3 have been recommended. I would also like to continue the tiling into an adjoining 35 square foot room with a clean concrete floor. I don't think too much build up of that floor will be necessary. Questions: will either of these products work to successfully cover the cutback adhesive? Is it possible to mix by hand or must I purchase/rent a mixer? Thank you.
kailuacathy is offline   Reply With Quote
Old 09-09-2010, 03:39 PM   #2
Tileguy
JazMan's Avatar
Hi Cathy,
Although anything is possible, parquet was not generally installed using cutback adhesive. It may be dark, but it may be the kind that actually dries hard which cutback does not.
If it is cutback, you can still install tiles on that floor with a little prep. You'll need to remove the cutback until only a film is left. In other words until you start to see the concrete. You'll need a wallpaper scraper which has a razor cutting edge and several hours of your time. Do not use any chemicals or solvents, they will soak into the concrete creating a bond break.
Either of the products you mentioned will be fine after the prep of the old floor and for the other area too.
You can mix by hand with a piece of 1x2 lumber or a margin trowel. Be sure to add the powder to the water already in the bucket. Of course a mixing paddle along with a good HD 1/2" variable speed drill motor is preferred. Mix at slow speed under 300 rpm.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
The Following User Says Thank You to JazMan For This Useful Post:
kailuacathy (09-09-2010)
Old 09-09-2010, 09:03 PM   #3
Hi Jaz,
I appreciate your time and information.
--Cathy
Tiling adhesive system aron.aron Flooring 6 01-19-2010 11:02 PM
Must you remove 100% of mastic residue before tiling? libbybuddy Tiling, ceramics, marble 4 06-12-2009 09:39 AM
Options for resurfacing over old cutback adhesive burlis Flooring 1 06-11-2008 04:35 AM
What adhesive to use for tiling wall? sz8 Flooring 4 03-21-2008 06:55 AM
sealing cutback adhesive Mikon Flooring 3 10-17-2007 11:08 AM
