Tiling Over Control Joint - Flooring - DIY Chatroom Home Improvement Forum
Old 02-17-2015, 04:06 PM   #1
Rewards Points: 236
So, I am planning to tiles my basement.
The concrete is 10 years old and it has a control joint.
It is my understanding is that I need to put a crack isolation membrane over the joint prior to tiling. My plan is to lay the tiles so that the grout line is over the joint.
Attached are pictures of the control joint. It has about 1" width and 1/2" depth.
My questions are:
* do I need to fill the joint with something (e.g. mortar) prior laying the crack isolation membrane?
* Do I need to apply crack prevention (e.g. RedGard) below the membrane prior to applying the mortar and then tiles?
* How wide of membrane does it need? Is it just enough to cover the joint (e.g. 6" on each side)?
Thanks!
Tiling Over Control Joint-control-joint.jpgTiling Over Control Joint-control-joint-2.jpg
325_man is online now   Reply With Quote
Old 02-17-2015, 07:17 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That thing looks awful wide to be a control-joint. Are you sure it isn't an expansion-joint?
When covering a control joint the material used should reach out by two full tiles, depending on what product you are using.
On the other hand, expansion joints must be honored through the surface of the tile.
XXX
Old 02-17-2015, 08:50 PM   #3
Rewards Points: 236
Do I need to fill the gap there with anything?
My understanding between control joint vs. expansion joint is that
A control joint is a continuous vertical joint filled with mortar, but with a bond breaker on one side so that tensile stress cannot develop across the joint.
In other words, it is basically a groove cut into the surface of the concrete that allows some cracking to occur in the joint and not be readily visible.
An expansion joint is a continuous vertical or horizontal joint, left completely free of mortar and filled with elastomeric sealant to keep it watertight. In other words, it is between two separate pieces of concrete or between concrete and another material.
Mine seems to be a control joint as it is a continuous filled with mortar and there is no gap (other than the crack) and no elastomeric sealant in the joint.
Having said that, I don't see any other joint in the whole basement.
Old 02-18-2015, 03:42 AM   #4
I would tile to the joint then caulk.
ron45 is offline   Reply With Quote
Old 02-21-2015, 08:11 AM   #5
Rewards Points: 236
Have you all try product like Schluter Surface Movement Join?
Old 02-21-2015, 10:44 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What is; "Schluter Surface Movement Join"? Never heard of it! How about providing us with a link to "Schluter Surface Movement Join".
XXX
Old 02-21-2015, 05:11 PM   #7
Rewards Points: 236
http://www.schluter.com/4_20_dilex_bt.aspx
Old 02-21-2015, 06:09 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well why didn't you say so? That product has been around for many years.
XXX
Old 02-21-2015, 07:03 PM   #9
Rewards Points: 236
So, is this better than using crack isolation membrane?
Thanks!
Old 02-21-2015, 07:29 PM   #10
Your money.
I would tile up the joint and caulk it.
Cultured Stone Veneer and Fireplace Mantels- Joint or No Joint? Irish916 Concrete, Stone & Masonry 3 09-04-2014 09:47 PM
Soldered Copper - Bad Joint? alfer Plumbing 5 03-23-2013 11:02 AM
Dishwasher Control Panel Zen Nomad Appliances 0 10-02-2010 12:00 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
Ceiling Fan Speed Control czars HVAC 0 01-14-2010 09:06 PM
