Tiling Over A Concrete Joint - Flooring - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 07:07 PM   #1
Question
tiling over a concrete joint
Hi, I have extended my house, therefore a new concrete slab has been added to the existing slab. I want to tile the complete floor with ceramic tiles.
When the slabs were joined together there was an existing brick wall between them, I had to remove these brick (two courses) after the new slab was poured. The slabs were joined with steel bars under the two courses of bricks, there is a thickness of 300mm below where the bricks were. Now the bricks have been removed, the gap has been filled with concrete, there are now two joint lines between the slabs to a depth of about 200mm.
My questions are, a) can this be tiled over using a flexible adhesive only? or b) does the complete floor have to be screeded over with a morter base?
My objective is to avoid cracking in the tiles. I have had Tiles look at the job, but they have given me advice saying that both ways are as good as each other, I'm confused not knowing which way to procede!
Thanks in anticipation.
dave60 is offline   Reply With Quote
Old 03-06-2011, 08:16 PM   #2
woodman58's Avatar
You can use a crack isolation membrain over the area. This is new concrete next to old. The new will probably settle and crack within a few years. I would find someone that knows about concrete to ask.
I doubt that the people doing the concrete will warrenty against cracks.
woodman58 is offline   Reply With Quote
Old 03-07-2011, 06:36 PM   #3
Thanks Woodman58, do you know if this is available in Australia?
Old 03-07-2011, 06:58 PM   #4
Woodsman has got it right. The other choice is kerdi ditra mat (check my spelling) You will have both of them down under.
masterofall is offline   Reply With Quote
Old 03-07-2011, 08:18 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 310
I love Ditra but, Ditra is not a crack isolation membrane. You still have to honor the cold joints.
Noble's CIS is the ticket. http://www.noblecompany.com/Products....aspx#products
Not sure if they'll ship it to OZ though.
I'm sure you have liquid applied membranes and easy to find there.
Jaz
Old 03-07-2011, 08:24 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I wouldn't do it at all.
I would cut tile to fit the location of the removed brick then install two soft-joints on either side of that tile. Make it a decoration kind of thing. Nothing you cover the splice with can be guaranteed not to crack the tile in that case. You must honor the new joint through the tile at the very least.
XXX
Old 03-07-2011, 08:33 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 310
Bud is absolutely right about making the cuts. A membrane will do what it says it'll do, BUT no membrane, whether sheet or liquid, will help if the slab drops or raises. Better to just make cuts and treat it as what it is. Be sure the gap is minimum 1/4" regardless of the selected grout space for the remaining area.
Jaz
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 06:03 PM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
Concrete Repair Help / Contractor Problems thp Building & Construction 12 09-24-2009 02:01 PM
Tiling a porch over a painted concrete surface Harls Building & Construction 1 07-14-2008 08:34 AM
