Tiling Over Concrete Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-01-2010, 06:47 PM   #1
Rewards Points: 85
I'm thinking about installing ceramic tile over a concrete basement floor. The floor is flat for almost all of its expanse, but within a couple feet of the corners it starts to curl upward, and ends up higher by almost an inch.
The tile that I am thinking of using looks like wood planks, and is 6 inches wide by 24 inches long.
How do I overcome the problem in the upward-curling corners?
MrBill_DIY is offline   Reply With Quote
Old 10-02-2010, 05:43 AM   #2
I personally would break out my grinder with a diamond wheel on it and grind it down. Being the grinder is round you would have to chisel the corner out. This can be dusty so you would need a vacuum. My grinder has a dust guard with a vacuum attachment, so if you can get a grinder with a diamond grinding wheel on it I would do that. If you can't rent a grinder with a vac attachment just have someone hold the hose right by the wheel as it grinds. Be ready for some dust and get some dust masks.
JCW355 is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Painting concrete basement floors shimga Flooring 3 04-24-2010 02:46 PM
Tile over basement concrete floor? BowDown Flooring 2 05-08-2009 08:41 AM
