Tiling Over 1/4" Plywood With Linoleum - Flooring - DIY Chatroom Home Improvement Forum
Old 04-22-2014, 10:06 PM   #1
Tiling over 1/4" plywood with linoleum
Our house was built in 2005. I am trying to replace linoleum in the entry way and install tile. I have my hardiebacker boards cut and ready to go. My current floor consists of 5/8" floor board-1/4" plywood and then linoleum. Everything I read is telling me to pull out the 1/4" plywood. I can't rip out the linoleum cause it is glued to the max. Do I have any options other than ripping out the plywood? I am also upset because the rest of the house (which we want to eventually do hardwood and more tile) has the same stuff...1/4" plywood and linoleum. I want to do this right even if it means the pain in the rear... Please help, and why would they do this? Is it to have a better adhesive to the linoleum? I'm also curious if the 1/4" plywood is the cause to a low spot in hallway...I can almost feel the two sheets of flooring under the carpet where they meet together. Sorry there is a lot here just figuring all this out and not too excited about it. Thanks
Gwarren82 is offline   Reply With Quote
Old 04-22-2014, 10:20 PM   #2
Rewards Points: 744
The 1/4" underlayment was put down, in order to have a smooth surface under the lino/vinyl. Regular plywood subflooring isn't smooth enough for vinyl/lino. without the 1/4 underlay, all of the grain lines would project through the lino.
I have 1/4" ply under my cement board....no problems so far. But, I also know that there are a bunch of fasteners.
5/8" subfloor seems a bit small. I'm sure one of the tile pros will be by to advise further. They'll also want to know your joist spacing, size, unsupported span, and species.
We have no way to know what's causing low spot in your hallway. You'd have to remove the carpet and pad, and take a look.
Seattle2k is offline   Reply With Quote
Old 04-22-2014, 10:23 PM   #3
Thanks!
Old 04-22-2014, 10:31 PM   #4
Rewards Points: 13,450
Even if you did (and you should) removed the 1/4, 5/8 is not suitable for tile. It's to thin.
Going to have to go over that with at least 3/8 A/C underlayment rated plywood.
A couple cost effective options to consider might be laminate or strip flooring that looks like tile.
Old 04-22-2014, 10:33 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 340
Hi Warren,
What is 5/8" floor board? Do you mean plywood subfloor by chance?
Well, I doubt that very much but it doesn't matter cuz you should remove the 1/4" underlayment with the vinyl still attached.
It's done that way because it's the right thing to do when installing most resilient floors.
The 1/4" should only be under vinyl, not under carpeting, but who knows? Underlayment is not gonna change, eliminate or cause low or high spots.
I see Seattle posted while I was writing. Answer the questions about how the framing is built. Try to determine the grade of the joists too.
Jaz
Old 04-22-2014, 10:42 PM   #6
Good info thank you. I will have to double check the joists.
Tags
hardiebacker , linoleum , luan , plywood , tile
OSB + Plywood = solid base for tiling? Denisrus Flooring 35 05-18-2012 11:13 PM
Tiling over plywood floor 3 season porch matt7125 Flooring 12 04-22-2011 06:22 AM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
1/4" plywood floor llorain63 Building & Construction 9 10-09-2010 08:26 PM
