Tiling The Outside Of The Acryllic Tub - Flooring - DIY Chatroom Home Improvement Forum
Old 07-20-2007, 01:51 AM   #1
Tiling the outside of the acryllic tub
Hi I was wondering if it is possible to tile the outside wall of atub (i.e., the side that faces out into the room). Has anyone ever done this, were you successful, and how did you do it?
(I figure I will have to rough up/sand the surface for any mortar to stick, and the top 1/3 of the right end of the tun is beveled, so how is the best way to even this out? Is it possible to attach that backer board to the side of the tub...?)
Thanks in advance!
Nicole
nalxs is offline   Reply With Quote
Old 07-20-2007, 07:32 AM   #2
RippySkippy's Avatar
I'll be interested to see the responses...don't need to, don't want to...it just sounds interesting...
RippySkippy is offline   Reply With Quote
Old 07-20-2007, 11:35 PM   #3
remodeling pro
Never done it, but I believe you could rough up the acrylic with some 40 or 50 grit discs and use latex modified thinset to bond cement backer board to it. Don't understand your description of the beveled part exactly, so no comment on it.
troubleseeker is offline   Reply With Quote
Outdoor Tiling kirkeric Flooring 5 08-15-2007 06:37 PM
Tiling inside a fireplace Patricia Building & Construction 4 09-02-2006 08:51 PM
How scuffed should old tile be before tiling over w/ new J187 Flooring 3 07-25-2006 09:01 PM
Tiling questions with pictures. J187 Flooring 11 07-18-2006 08:24 AM
bathroom tiling neptunian General DIY Discussions 1 03-29-2005 08:44 AM
