Tiling New Construction - Flooring - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 02:55 PM   #1
Tiling new construction
Should I tile a new construction bathroom before I install the door and jamb? So that the tile would be underneath the door jamb? Or should the door jamb go in first so that the tile comes up to it flush?
groundtrac is offline   Reply With Quote
Old 11-23-2008, 04:42 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
When you have the opportunity..tile first, jamb last.
Old 11-24-2008, 08:02 AM   #3
Rewards Points: 129
I just went through the process you are in now. We hung the doors first...but we used spacers as we hung them. Set your prehung doors on the spacers as you install it in the rough opening. The pull them out after the door is nailed up. You still may have to trim the jambs when you lay tile...but at least you shouldn't have to trim the bottom of your doors...
poolecw is offline   Reply With Quote
Old 11-25-2008, 10:00 AM   #4
Great!
Thanks for the great advice! I'll let u know how it turns out.
Old 11-25-2008, 04:31 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Then what would be the point in that? Why chance splintering the door jambs if you don't have to?
Shouldn't have to do that either, all interior doors are shorter than the jambs when they are new. They do that to allow for the floor covering materials.
Old 11-26-2008, 05:06 AM   #6
Jill_m is offline   Reply With Quote
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 01:47 PM
Tiling bathroom ivaiva Project Showcase 3 08-30-2008 08:24 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
Which is better? (Non-vented roof construction with indoor pool) elbartee Roofing/Siding 21 03-26-2008 11:05 PM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 03:57 PM
