Tiling My Kitchen Floor, Couple Of Questions - Flooring - DIY Chatroom Home Improvement Forum
Old 03-24-2008, 07:33 AM   #1
Tiling my kitchen floor, couple of questions
I want to tile my kitchen floor with 20"x20" ceramic tile. I want to pull up the 1/4" underlayment, then put down 1/4" cement board, then tile. Do I need to be worried about the weight issue on the floor due to the new tile? Do I have anything to be worried about or can I go ahead and get started?
Yeti is offline   Reply With Quote
Old 03-24-2008, 01:11 PM   #2
RippySkippy's Avatar
With the information you've provided, no one here can give yo any good information.
What type of joist do you have? And what's their spacing?
What kind of sub floor do you have? Thickness.
What kind of span do you have between joist supports?
If you're working with standard dimensional lumber, you can get an idea of the floors ability to support the load by using the Deflecto meter over at John Bridge's site...
RippySkippy is offline   Reply With Quote
Old 03-24-2008, 02:55 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Here's a dumb question!
What kind of tile? Ceramic or stone?
Old 03-24-2008, 03:23 PM   #4
Ceramic
Old 03-24-2008, 05:49 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That's in your favor!
Now:
Old 03-24-2008, 06:30 PM   #6
Now:
The kitchen is 13'x15', with the joists running in the 15' direction. They actually measure about 9". They are 16" on center. There is 1/2" plywood for the subfloor with I believe 1/4" underlayment on top of that. How can I beef up the floor? There is also a crawl space underneath so I have fairly easy access. Do I need some sort of vapor barier? Can I run supports down to the slab, and make the 15' span supported in the middle? How do I brace it?
Old 03-24-2008, 08:26 PM   #7
remodeling pro
Things for worrying:
How strong is the floor as far as the amount of deflection it has...is it bouncy. If so, the joists may need to be stiffened so the tile doesn't crack.
How flat is the floor. The larger the tiles, the more critical the flatness of the sub-floor is.
troubleseeker is offline   Reply With Quote
Old 03-24-2008, 09:27 PM   #8
They probably need to be stiffened. Whats the best way to do this?
Old 03-27-2008, 12:43 PM   #9
Tile and Paint contractor
From your dimensions your floor deflection doesn't meet L / 360 requirements. You need at least that to install ceramic. And L / 720 for stone installations.
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Old 03-27-2008, 02:25 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
HOLD ON Yeti!
What EXACTLY is the free span of your floor joists? Measure it! Also try to determine the species of the lumber used for joists, there may be stamps somewhere.
Your conditions are marginal but if your actual span comes in under the stated 15 foot then you may get under the wire.
Old 03-27-2008, 02:26 PM   #11
We've determined it needs to be stiffened, the next question is what is the best way to do this? Can I just sister another joist onto the ones that are already there?
Old 03-27-2008, 03:00 PM   #12
HOLD ON Yeti!
The span is about 15 1/2', do you think the 1/2' is enough to make a big difference? Also, there are two feet of cabinets along the one wall where there will be no tile.
Old 03-27-2008, 04:49 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes it needs to be improved. If the span was around 14 feet you would be in under the radar but you didn't make it.
Is there a basement?
Old 03-27-2008, 07:08 PM   #14
crawl space
Old 03-27-2008, 09:15 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Beam and jack it midspan.
Kitchen Wiring Questions Chazbe Electrical 22 04-11-2008 04:06 PM
Tiling a bathroom and hallway questions Roddy Piper Flooring 11 02-07-2008 03:35 PM
tiling kitchen...how to treat electrical outlet on floor? tarheelblue Flooring 3 01-28-2008 03:31 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 05:06 PM
Tiling questions with pictures. J187 Flooring 11 07-18-2006 07:24 AM
