Tiling My Garage - Flooring - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 11:39 AM   #1
Tiling my garage
Hello all. I have a question that has probably been asked a million times. What do you recommend for installing porcelean tile over a concrete garage in Southern California?
My garage was poured in 1995. It measures 28x36 ft. It has one saw cut joint bisecting the garage. There are a few hairline cracks with no separation. I have about two dozen bolts that were shot into the floor that I need to cut off, from walls that I removed.
I recently purchased some "seconds" 20x20 porcelean tiles. I am trying to decide if I should just lay them on the concrete with crack isolation over the joints and cracks or should I use a full coverage barrier. I've heard people on the net recommend ditra. Some local folks recommend NobleSeal.
This is a garage and I'm baulking a bit at the price of full coverage NobleSeal after pricing out NobleBond Primer, NobleSeal CIS, and NobleSealant 150 for full coverage. At the same time, I don't want cracks and cutting corners is almost never the long term economical solution.
I'm also wondering what a good tile transition is for the garage entrance.
What do folks recommend?
Thanks,
Carl
Gentleman Farme is offline   Reply With Quote
Old 03-02-2011, 01:06 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
Just curious, what will the garage be used for?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-02-2011, 01:25 PM   #3
For now, two bedrooms and a rec room. In about 3 years, back to Diesel excursion, truck, and tractor
Old 03-02-2011, 01:52 PM   #4
Rewards Points: 142
When you go back to vehicles, that will be extremely slick if it gets water or oil on it.
Old 03-06-2011, 04:03 PM   #5
Rewards Points: 81
My car has inexpensive ceramic tile in it. It has held up to jacks, tools, and a recent engine swap without any issues at all. It's rated for public use and is not slippery when wet, like high-glaze bathroom tiles might be. It was .59/sf and I installed it myself. There is no underlayment, and my old slab dates back to 1925. I double-buttered the thinset and used ordinary grout in a darker color in case oil might stain them. I've had it for years now, and I have no complaints at all.
What you can't see in this last picture is the 500# engine perched on a floor jack being rolled across the tile.
I drop lots of tools on it. Oil and other fluids wipe right off with a paper towel or rag. The only thing I have to think about protecting it from is welding slag.
Jack Olsen
The 12-Gauge Garage website
My Car
Jack Olsen is offline   Reply With Quote
Old 03-06-2011, 05:16 PM   #6
I hired a guy yesterday. He is starting tomorrow. Garage isn't very planar, he is going to float it. Anything I should watch for? Crack isolation goes down before any floating right?
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 07:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
