Old 08-28-2008, 11:18 PM   #1
The Carpenta!!!
ManMythLegend's Avatar
Tiling layout
I'm interested in tiling my kitchen and laundry in the same pattern. What's the best way to snap lines. I think I know, but would like clarification.
Here is the layout
I WILL PERSIST UNTIL I SUCCEED.
I AM A LION AND I REFUSE TO TALK, TO WALK, TO SLEEP WITH THE SHEEP.
THE SLAUGHTERHOUSE OF FAILURE IS NOT MY DESTINY.
ManMythLegend is offline   Reply With Quote
Old 08-29-2008, 12:12 AM   #2
Tileguy
Bud Cline's Avatar
Tiling layout
Use a chalk box!
OK OK OK, sorry 'bout that!
You must determine what you want to see. If "balance" is of the utmost importance to you then that's easy. Evenly divide the area and go for it.
If you want more design appeal and balance doesn't make that much difference then you need to determine the best placement of the layout for visual impact. Not all tiles have to balance in that case.
For example maybe the kitchen is more important visually than a laundry room so the layout should favor the kitchen focal points and take what you get in the laundry room if you want the tile to flow continuously throughout the area.
Take a look and see what you want to do. Then layout your floor accordingly.
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Tiling bathroom ivaiva Project Showcase 3 08-30-2008 09:24 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 04:44 PM
bathroom tiling neptunian General Discussion 1 03-29-2005 08:44 AM
